I am creating a DMX receiver circuit. The dmx that is received from a controller (USB DMX dongle) is converted via a transceiver (SN75176BP) to a signal which can be understood by an ATMEGA328P.
I now have the problem that it is not recognized. When I measure on my circuit at RX I get the signal that can be seen in the image. I think it is not working due to the fact that a 40+ Volts signal is supplied which can not be read by the ATMEGA328P.
Can someone explain to me why the signal can be 40+ Volts and how I can solve this in a good way so that my micronctroller can properly read this signal. enter image description here
DMX signal schematic
    You might wish to edit your question to explain what is generating the 40 V signal. That looks ridiculously high. Welcome to EE.SE. – Transistor Sep 03 '18 at 17:21
    Just checking: You are using a 10x probe, right? Because looking at the scope picture it says 10x for the yellow trace, which I think might mean that the scope thinks you are. If you are using a 'normal' 1x probe, the scope multiplies everything by 10, and you're getting a wrong reading. If this is the case: 4.5V on your RX pin seems perfectly normal for a 5V system. – MartinF Sep 03 '18 at 17:31
  • `Schemes that use voltage outside of the range allowed by EIA485 are disallowed.` From wikipedia page: https://en.wikipedia.org/wiki/DMX512 – DaniFoldi Sep 03 '18 at 17:33
The answer is clear now, it was indeed the probe settings. My probe has 2 settings. 1X and 10X. it was on 10X but somehow it is reading as 1X. Thanks @MartinF
