I would like a little insight on choosing a Mosfet for a hotwire cutter. The wire runs 12v @ 2A
I am planning on using a 555 PWM circuit to control the temp on the wire. I plan to use the PWM signal through a mosfet to do this.
I have never used a mosfet for this before. If there is one that would run fine with out a heat sink that would be awesome as the whole project has to be as low cost as possible.
If anyone could recommend one or two I will have a look at the specs. I can post a circuit diagram if needed, not quite complete yet.
