Brief
I built part of the scheme below (input K2/IC5, optocoupler IC9 and output IC6/K3). IC9 is overheating when I connect LED pars to K3, because voltage is flowing back into pin 6/7. If I connect pin 6 OR 7 all is ok, when I connect both, after a few minutes IC9 is overheating.
Question: What should I change to the circuit to fix this? Leaving one of the pins unconnected seems wrong.
(note the LED pars do not have any problem with a regular/commercial DMX controller).
Background
This is a follow up of wire to VDD or GND.
Using this circuit (build only one of three outputs:
(credits of circuit: http://www.chameleon.rs/e035020.pdf), design by J. Mack.
It works perfectly, however after a few minutes it stops. The reason is that IC6 gets too warm.
However, I don't have an LTC485 but used a MAX487CPA. After about 1 minute it gets warmer (touchable but warm), and soon it stops transmitting (or at least not what is supposed to send: DMX signals). DMX lights starts to flicker and than stops. When I let it cool down for about 30 seconds, it starts again, for another minute.
Than I tried SN75176BP. These last a few minutes before starting to show the same problems.
Tests I did:
- Disconnecting the output DMX lights ... this solves the problem, but of course doesn't help me. But I know there is current flowing back into IC6.
- I tried to add diodes between IC6 and K3 + and -. I would expect current could not flow back, but sadly the lights don't turn on at all anymore.
- I tried resistors (100 ohm and 330 ohm), but also: no lights turned on.
- What helped (so it is a solution) is to disconnect the IC6 to K3 + connection, meaning only the K3 - connection is intact (also GND is not connected).
However, I have the feeling this is not the 'correct' solution by not using the K3 + connection, although it works perfectly for now (2 lights, about 8 metres of not even DMX but microphone cable). (Note: eventually I will use only DMX cable, but not having enough at hand now).
What would be the proper solution to prevent too much current getting into IC6 (and later IC7 and IC8) ?
(btw, I also haven't used the separate AC transformers, now using 5V common breadboard power).
More tests
Without any load (receivers connected but not switched on), without any IC connected:
Hardwired: Measured Remarks
K3+ K3- K3+ K3-
0 V 0 V 0 V 0 V
0 V 5 V 0.57 V 1.40 V Breadboard power led less bright
0 V 5 V 0.42 V 1.57 V Breadboard power led less bright, 2nd measurement
5 V 0 V 1.65 V 0.7 V Breadboard power led less bright
5 V 5 V 5.28 V 5.28 V (same as +/GND difference on breadboard)
More tests 2
IC6 is RS485
Off means: breadboard power off
+ means: IC6 output pin 6 or 7 connected to K3 +
- means: IC6 output pin 6 or 7 connected to K3 -
unc means: IC6 output pin 6 or 7 unconnected
IC6.x means IC6, pin x
Settings Measured Remarks
IC6.4 IC6.6 IC6.7 | IC6.6 IC6.7
Off unc - | 0 -0.52 Voltage going back from 2 LED Par
Off unc - | 0 -0.33 Voltage going back from 1 LED Par
Off unc + | 0 -0.52 Voltage going back from 2 LED Par
Off unc + | 0 -0.33 Voltage going back from 1 LED Par
Off + unc | 0 -0.52 Voltage going back from 2 LED Par
Off + unc | 0 -0.33 Voltage going back from 1 LED Par
Off - unc | 0 -0.52 Voltage going back from 2 LED Par
Off - unc | 0 -0.33 Voltage going back from 1 LED Par
Off + - | -0.49 -0.48 Voltage going back from 2 LED Par
Off + - | -0.29 -0.30 Voltage going back from 1 LED Par
Off - + | untested
0 V + unc | 4.85 0.61
0 V - unc | 4.84 0.61
0 V unc + | 4.78 0.50
0 V unc - | 4.78 0.50
0 V + - | 4.83 1.21
0 V - + | 3.69 1.20
5 V + unc | 0.51 4.79
5 V - unc | 0.51 4.80
5 V unc + | 0.61 5.16
5 V unc - | 0.61 5.17
5 V + - | 1.22 3.67
5 V - + | 1.22 3.68
More tests 3
I found out the power of the breadboard is burning very little even when it is switched off. When switching off the PAR leds (output) the breadboard power light was still on, only when I switched off the DMX Light controller (connected to K2) the breadboard light went off. This means the problem is likely (or too) in the input.
So I did some more measurements:
Relative with +5V Relative with GND
breadboard breadboard breadboard breadboard
off on (5V) off on (5V)
K2- 0.23 V 3.23 V 1.68 V 2.04 V
K2+ -0.39 V 2.40 V 2.31 V 2.87 V
IC5 pin 1 (output) 0.60 V 2.07 V 1.31 V 3.20 V
IC5 pin 5 (GND) 1.42 V 5.27 V 0.00 V 0.00 V
IC9 pin 2 (input) 1.00 V 4.43 V 0.92 V 0.84 V
IC9 pin 6 (output) 0.54 V 3.27 V 1.60 V 2.07 V
IC6 pin 5 (GND) 1.42 V 5.27 V 0.00 V 0.00 V
IC6 pin 6 (-) 0.54 V 3.27 V 1.37 V 2.00 V
IC6 pin 7 (+) 1.90 V 2.17 V 0.00 V 3.10 V
Strange measurements:
- When measured towards +5V GND is not +5V (difference) as expected.
- Difference between IC6 pin 6 and 7 is maybe not high enough (rel to 0V)
- Pin 7 with +5 reference is 0.00V.
