I just ran the DRC check in Altium for my PCB and I get errors on trace width for every trace segments on the board.
What is the reason for this ? It generated thousands of errors even tho all the traces are 4 to 5 mils wide.
All tracks width rules are set to >= 4 mils
This is the error message I get under "Rule Violations" :
Clearance Constraint (Gap=3.5mil) (All),(All)
Clearance Constraint: (Collision < 3.5mil) Between Track (52761.3mil,31343.2mil)(52769.499mil,31343.2mil) on Solder Side And Arc (52769.499mil,31340.4mil) on Solder Side
Edit: It also affects trace much much larger than 3.5 mils
GmodCake
  • 574
It turns out it was in the clearance rule I selected "Any nets" by mistake which meant the rule was applied to any segment no matter what net it is from, changing it back to "Different nets only" fixed it.
GmodCake
  • 574
The image you've attached is for Minimum Clearance between components. There should be another dialog that defines the minimum and maximum trace widths. Double check that they are correct.
Tim Vrakas
  • 441
What ARCs is it referring to? From your picture, I can't see any.
Use the PCB Filter "IsArc" to see where these mystery geometries are coming from.
Did you accidentally convert your vias to free pads? I could see that causing some issues for the DRC.
NP3228
