I usually follow the following wiring scheme for RS422 wiring:
As seen above R+ to T+; R- to T-; T+ to R+ and T- to R-. So for each point to point wire R and T coupled but the signes are same i.e + to + or - to -.
The above wiring scheme was working with different type of converters.
But recently I needed to use this converter hub.
For each port it has the pin assignments as shown:
But when I wired this as RS422 as usual it didn't work I didn't receive or send data through Hyper-terminal. But when I wired it as following it worked:
DB9 port pin -->Instrument pin
pin1 TxD- -----> TxD+
pin2 TxD+ -----> TxD-
pin3 RxD+ -----> RxD-
pin4 RxD- -----> RxD+
pin5 GND to GND
It works as above but this is very different than usual wiring. Im really confused what could be the reason?
floppy380
  • 1,715
  • 67
Most folk wiring up differential serial interfaces just assume the there are two TX wires and two RX wires and that if it doesn't work with the first attempt then you swap things round and then it works. There's never a complaint because when it works, you have it the right way no matter what the legend on the label or in the data sheets says. When a label/document author gets it wrong, the world doesn't come to an end thankfully and usually it's never noticed or reported because it isn't that big a deal.
If it works it's right! If it doesn't work, swap it. If it still doesn't work then that's the time to worry.
Looking at the two differential signals that might be labelled plus and minus, there is nothing about them that are positive or negative in nature; one is just the digital inverse of the other but both will have the same common mode voltage so it really is an arbitrary decision as to which is labelled plus and which is labelled minus.
Please also read this document that explains that these sorts of errors do occur: -
What if I'm Unsure?
Reversing the two lines in the differential signal is by far the most common initial error when connecting two pieces of RS-422 or RS-485 equipment. The good news is that it won't cause any damage to your equipment to try it the wrong way. If you try it connected one way and are seeing garbled data, reverse the leads and try again.
RS422 (and RS485) driver IC's usually refer to the signals as A and B, and the usual convention is that signal A is non-inverted, signal B is inverted. So you could think that signal A is "+" and B is "-". But your new converter hub appears not to follow this convention. See how they labelled the terminals: TxD-(A). They are saying it is signal A, but denote as as TxD-, opposite to your usual method.
Steve G
  • 5,275
    The common convention is A/Tx-/Rx-/D-, B/Tx+/Rx+/D+, so the hub manufacturer actually got it right. However according to [wikipedia](https://en.wikipedia.org/wiki/RS-485#Signals) about half of the chip manufacturers use reversed labels for pins. – Maple Jul 31 '18 at 15:42
