TIA = transimpedence
I have lots of photodiodes for barrier detection, I tested one photodiode with one TIA op amp, and it was OK
1) Now I want to multiplex multiple photodiodes for my project, and I use 74HC4051 IC for that, I read in datasheet that between each of inputs to output 60 Ohm resistor, what's the effect of this resistor ?
2) I read this application note for TIA pcb design, and in this article author implied that the photodiode should be as close as possible to TIA because of the very low current of photodiode and TIA input bias current, It's very good for one photodiode, But when I use multiple photodiodes, I'm forced to place some photodiodes far away from TIA (40 photodiodes), what should I do for this in circuit design ?
