My current system:-
I'm working on a electricity metering system ,
I'm using shunt resistor configured in high side mode (a current sensor ) ,
I'm also using ADE7755 measuring chip ,
A schematic of the current circuit :-
A higher resolution schematic here
The problem:- When connecting the circuit as shown in the above schematic , R1, R2 , R3 & R4 blow up with some fire .
This isn't the first time happens , it happened before 3 times .
My initial guess it's that Analog & Digital ground are connected some how ..
I'm ready for any questions to clear the problem , thanks .
UPDATE#1 :-
I connected the PIN AGND in ADE 7755 chip to the Digital ground
stevenvh
  • 145,145
  • 455
  • 667
xsari3x
  • 1,608
  • 42
    What's the idea of posting an 11 Mpixel BMP image for a *schematic*? If you would use the PNG format it would be less than 100 kB, so you wouldn't need the ZIP. And you can easily scale it down by 75 %, without any concessions to readability. I edited the link. – stevenvh Aug 25 '12 at 18:19
  • @stevenvh for ppl who need zoom (like me :D ) thanks =) – xsari3x Aug 25 '12 at 18:24
  • I think you can do other things for better readability than going to huge image sizes. For instance there's a line running through the values of R3 and R4. Wait until [Olin](http://electronics.stackexchange.com/questions/28251/rules-and-guidelines-for-drawing-good-schematics) sees this :-). – stevenvh Aug 25 '12 at 18:30
If you look closely at the datasheet, you'll see that it plainly says the maximum signal you can apply to the amplifier inputs with respect to analog ground is +/- 1V (+/- 6V over voltage tolerance).
Your high-side current transducer is going to put a lot more common-mode stress than that on those pins, hence the blow-ups.
Consider a low-side sensor or an isolated transducer like a current transformer that can be referenced to the IC return.
Be safe - playing with the mains can be lethal. (I'm glad to see a fuse in your circuit!)
Adam Lawrence
  • 32,921
  • 58
  • 110
