I have a flex-PCB that is acting as a sensor bus for one of my projects. I started getting some wonky readings from one of the sensors, but I found that if I removed the sensor from the bus (with minimal heat) the sensor was working fine. Before applying the heat to the fPCB, I noticed that the solder mask above the ground and signal traces had begun to deteriorate. I feel like I have two pieces of a puzzle, but I just don't know how to put them together. Does anyone have any idea what else is worth my investigating?
What's on the bus? Digital signals, or analog? High impedance? Moisture + dirt = high resistance paths. – gbarry Aug 25 '12 at 16:40
analog signals, I have a bias voltage (~2v), ground and a series of signal paths. – thron of three Aug 27 '12 at 13:56
Photos of your degraded flex-PCBs would be helpful in diagnosing the issue.
You need to figure out if your PCB degredation is due to electical or environmental stress.
Environmental stress could be things like high ambient temperature, humidity, UV, corrosive environments (high salt content) and the like. It could also be application-related stress - excessive mechanical stress or flexure.
Electrical stress is less likely - usually solder mask degredation is caused by heat (excessive current) or breakdown due to excessive voltage causing arc-over. Your description of a low-voltage sensor doesn't fit this bill.
If you can't establish a sure environmental or electrical cause, it would be worth your while to get in touch with the flex PCB vendor and ask for some failure analysis. They should be able to establish the cause of the degredation.
- 32,921
- 3
- 58
- 110
