I'm working on a project where I should send an overload signal if the strain is bigger than 40 ppm.
So far I found this answer:
Strategy to balance a Wheatstone bridge for strain measurement
The wheatstone bridge consists 2x 120 ohm, GF 2 strain gauge and two 120 ohm 0.1% resistor.
Using the answer above I'd make it so that at 40 ppm the in-amp's output would drive a JFET.
I think that a ina-128 would be a good choice, but the power source is x piece 1,5 V battery so I'd need 4.
Is it a good choice, can you recommend a better for this application?
