For example, I have a motor that needs a surge of 2.5A for a short amount of time from a 6V power supply.
Will any 6V battery able to supply that current? Even if let's say it has only a 500mAH. How does AMP rating matter when talking about this?
AznBoyStride
  • 149
  • The DCR of the motor must be much higher than ESR of the battery . A 9V cell is higher. What is the motor DCR? And battery ESR=Voc/Isc – Tony Stewart EE75 Jul 13 '18 at 22:58
  • Do you mean "9V battery" (i.e, PP3) in your question, or some other type of battery? If the latter, what kind? –  Jul 13 '18 at 23:00
    related (if not duplicate): [Battery Ampere-hour rating vs Battery Amps](https://electronics.stackexchange.com/a/122734/7036) – Nick Alexeev Jul 13 '18 at 23:18
  • Conventionally you'd want a battery rated for high discharge current. However, particularly if you can *anticipate* the need, you may be able to do something with capacitors that you charge up slowly to deliver a brief current pulse. – Chris Stratton Jul 13 '18 at 23:29
  • a 9V battery is made from six AAAA cells .... it has a lot of internal resistance .... it does not produce much current as a result – jsotola Jul 14 '18 at 01:38
  • 2-5A into a short circuit. – Jasen Слава Україні Jul 14 '18 at 06:50
You might want to use rechargeable NiMH batteries instead of alkaline cells.
This Energizer AA NiMH cell is specified for 4.6A continuous discharge current, for example - way more than typical alkaline cells can provide. It'll probably provide even more current for a few seconds. Plus, you can recharge it!
Five of those in series and off you go.
Jonathan S.
  • 14,865
  • 50
For a common 9 volt battery - almost certainly not
4 AA alkaline cells (6 volts) - possibly
4 C alkaline cells (6 volts) - much more likely (although I've seen some C cells that have the same specs as AA cells)
Peter Bennett
  • 57,014
  • 127
