If one computer sends data, for example 001101, how does the other computer know, where one bit starts and the other one ends? If you were just to monitor the change, you would get 0101, which is totally inaccurate. Is it just a timing thing? (I apologise if this is a noob question)
1It's a noob question perhaps, but a good one. It may have been asked and answered several times here on stackexchange, but the question might be worded differently. – Bort Jul 13 '18 at 16:20
This is specified by the communication protocol used. If you wish for a detailed answer, specify a protocol. For a start, search the interwebs about serial communication and UART. – Vicente Cunha Jul 13 '18 at 16:25
1Related question: https://electronics.stackexchange.com/questions/383960/does-computer-memory-record-the-zero-binary-state Have a look at the top answer. – Marco Zollinger Jul 13 '18 at 16:27
Perhaps you're talking about [decoding convolutional code?](https://en.wikipedia.org/wiki/Convolutional_code#Decoding_convolutional_codes) – Jul 13 '18 at 16:28
Depends on *how* it is sent. There are different communication protocols. You can check this one as related: https://electronics.stackexchange.com/questions/251341/how-does-uart-know-the-difference-between-data-bits-and-start-stop-bits/ – Eugene Sh. Jul 13 '18 at 16:36
See also https://electronics.stackexchange.com/questions/383960/does-computer-memory-record-the-zero-binary-state?noredirect=1&lq=1. – Transistor Jul 13 '18 at 17:21
sometimes timing sometimes there are multiple signals. sometimes a combination of timing and multiple signals. – old_timer Jul 13 '18 at 17:27
This very question was just asked here in the last week, though with a confusingly mischosen title. – Chris Stratton Jul 13 '18 at 17:31
Serial or parallel? You say "the signal" so that implies a single line. There's a range of [Serial protocols](https://en.wikipedia.org/wiki/Category:Serial_buses) and [Line encodings](https://en.wikipedia.org/wiki/Line_code). Do not assume that a '1' value is represented by a constant '1'/'high' level on the line; it generally isn't. Line encodings exist to make sure both that the output has regular transitions no matter what the bit-sequence was (so that receiver circuitry can reconstruct the clock and slice the data), also that DC component stays near zero (so no static power transmitted) – smci Jul 13 '18 at 23:07
This actually depends on the protocol. There are a _lot_ of different methods of communication. USB 3.0 has a vastly different method than USB 2.0, RS-232 is fairly trivial, PCI/PCIe is a horrendous mess that abuses the laws of physics, etc. – forest Jul 14 '18 at 03:47
And then there is the Environmentally friendly IT dept with the poster : Please Reuse Packets ... – Solar Mike Jul 14 '18 at 05:26
It's a timing thing (I don't like the word 'just').
In the case of a UART, in which the A stands for Asynchronous, there is a line idle state, then a start bit, which edge the receiver uses to synchronise its timing. After that, all the bits are sent each with an equal period. The word finishes with a stop bit, which ensures there is a transition into any following start bit.
- 158,152
- 3
- 173
- 387
Typically both sides have to know ahead of time what the bitrate is.
If not then you can sometimes detect the speed by looking at the shortest state change. 0000011111111101111111 but it may be a while and you may see something shorter.
Usually both sides know ahead of time. Some things like ethernet, pcie, etc will use a slow agreed on speed to talk to each other, then switch to or test a higher speed as part of a training exercise.
There are also bit encoding solutions, irig 106 chapter 4 if I remember right has a nice chart, with nrz-l,s,m biphase-l/m/s etc. When you use biphase, biphase-l in particular some industries call it manchester or manchester II encoding, either way, a bit is defined with a mid bit cell state change so each bit is two half bit cells with a high to low or low to high in the middle which determines a one or zero. For long streams of data or continuous data, you will never see more than two half bit cells at the same level by definition, making it much easier to bitsync to the otherside. so long as both sides agree the data encoding is biphase-l.
In addition to figuring out how often to sample, there is another typical problem if each side is using its own oscillator. So even with an agreed upon data rate each side drifts over time, so you have to solve that somehow. some situations like uart where your frame/message is very short you can use the start bit edge to both define where a mid bit cell sample would be for an agreed upon rate, and for that rate 10 cells or so you can have a fair amount of difference between clocks and it still works out. If you really wanted to for every edge that does show (if any) you can re-adjust.
In the telemetry world (the irig 106 thing) the data is continuous and the bitsync handles oversampling and keeping track, but you need some number of transitions over time to be able to do this thus those encoding solutions that insure bit transitions.
some protocols insure transitions in other ways. ethernet doesnt gracefully solve this, the receiver can/will use a recovered clock to sample the data, but the data once made into bytes and packets gets buffered and dealt with, if your crystal is a little slower than the crystal of the sender and you are at line rate, and you are doing a store and forward thing (are a router lets say) then you will eventually overflow your buffers and have to flow control. so that is the mechanism there.
then of course as commented, if you are synchronous instead of async, you "simply" carry the clock with you, but depending on the speeds and cable lengths there can be a shift between clock and data so that has to be dealt with. spi has this problem certainly as some products (like flashes) see your request that you sent on the rising edge, they start their answer on the falling edge and you sample based on your rising edge, so you have half a clock cycle for the round trip, if you for example put a cpld or fpga inline so that you can backdoor access the flash (rather than wire-or share the signals) you can make the round trip too long. QDR memory has this issue and some solutions for it as well, same story parallel data with a clock along for the ride if the signals have any timing issues you can be sampling one or both sides at the wrong time. pci carries a clock with it but it is the reference clock not the gigaherz clock used to make the data (its the reference clock used to make the gigahertz clock).
short answer, most of the time both sides agree on the speed ahead of time, either by protocol, fixed speed, or by a training exercise at an agreed/defined slower speed, or purely we simply agree like uart, I know the other side is 1152008N1 so I set my side to that. On occasion with uart for example you can detect a speed but you have to have the other side send characters that allow that...(have the right transitions not 00110011 but 101 or 010 somewhere.
- 8,203
- 24
- 33
3And let's not forget the most straightforward approach of all - synchronous transfer. Include a second signal path which contains a clock. – WhatRoughBeast Jul 13 '18 at 18:27
There are two general approaches:
Asynchronous
Asynchronous serial communication is a form of serial communication in which the communicating endpoints' interfaces are not continuously synchronized by a common clock signal.
A UART is a piece of hardware that enables a device to send and receive data asynchronously -- that is, not synchronized to a clock signal.
If you were to look at an RS232 serial port pinout, you'd notice that there are Receive Data (RXD) and Transmit Data (TXD) pins, but a "clock" pin is notably absent.
The two sides of the communications channel have to agree (ahead of time) to the rate at which bits are going to be sent. This is why you have to configure the baud rate (symbol rate) in order for your serial port devices to work.
You'll also see things like "start" and "stop" bits -- these are used to help synchronize the receiver to the incoming stream.
Asynchronous busses include:
- SATA
- UART
- USB
Synchronous
Synchronous communication requires that the clocks in the transmitting and receiving devices are synchronized – running at the same rate – so the receiver can sample the signal at the same time intervals used by the transmitter. No start or stop bits are required.
Synchronous busses use a clock signal, a square wave, that rises and falls at a very regular, specific rate. All of the other signals are synchronized to this signal; their values are typically sampled at a rising- or falling-edge of the clock.
Because the receiving end has a good clock reference, synchronous busses can run at a much higher rate.
Most on-board, chip-to-chip busses are synchronous, including:
- DDR
- I2C
- PCI
- 300
- 2
- 13
Back in the TTL days, disk drive blocks started with an alternating 0-1 pattern, which we synced to with a PLL. The pattern ended with 11 to indicate the start of the read data. The PLL provided the read clock, and a crystal oscillator (a whole 5MHz) was used for the write clock. The read data was sampled 1/2 clock between edges of the bit frame.
- 171
- 2
- 9
preamble still exists today, mostly to rebalance transformer coupled communications – Jul 13 '18 at 18:40
What you are asking about is synchronization. In order to communicate information across some link, you have to provide a way to synchronize the "bits" of information and their start. There are a multitude of approaches to accomplish this and all are tailored toward the physical environment (the PHY) that you are dealing with. More specifically, is this wires over a short distance on a PCB, so you might use a parallel bus, with a clock and read/write strobe (like memory), or a serial wired link (e.g. I2C, SPI, USB, Ethernet,...), power-line modem, fiber optics, I/R remotes, wireless RF, ... and many more.
More specific to your question, and as alluded to by some other respondents on this thread, serial communications falls into binary synchronous or asynchronous timing. The idea is that you need to recreate a clock to sample the data to see if the data bit is a one or zero (or a plus and minus voltage in some implementations like RS-232). If you separately send the clock as a separate signal then it is synchronous. If asynchronous, then you send the data and add extra information (known patterns at the start and stop of your transmission; or the data can be encoded with something like Manchester encoding which combines the clock and data in a clever way). The point here is that you need to trigger on the bit transitions that you receive in a way that calibrates your local clock, so you can lock onto the bit stream and sample it correctly during some frame length. Each new frame is a opportunity to correct your clock to the sender's clock to stay sync'd.
Also needed is a way to sync to the beginning of the transmission. This is can be done a number of ways, but is often based on a preamble pattern. A know pattern is used to discover the beginning.
Hope that helped - great question!
- 1
