Background
We want to waterproof an electronic device and the specifications call for IP-65 protection. To this end, we have selected a sealed polycarbonate box to put the electronics in. The external connectors are reduced to a minimum and we use automotive IP-67 connectors. We tested a few prototypes and they cope with submersion. I'm closing on any remaining issues that may cause water damage in operation.
I'm worried that atmospheric air that gets trapped inside when the device is fully assembled might condense if cooled significantly. Especially if assembly is in mid-summer.
It seems that this problem is tackled in the industry by displacing ("backfilling") the air in the enclosure with nitrogen, helium and/or clean dry air. I don't have any experience with these, but they seem to be expensive operations that only make sense for medium- to large-scale production, when you have the equipment required.
Question
What production technique can be used for small-scale production (10-100s/month) to keep the humidity of the air low enough so that it doesn't condense?
Non-solutions
The device has a display which needs to be visible through the transparent box, so condensation-resistance is a must. Conformal coating alone won't suffice.
The device is battery-powered, so keeping the innards at elevated temperatures is also not an option.
I've read the excellent question about waterproof enclosures and unfortunately the "leaks more on the bottom than the top" strategy cannot be used here. Moreover, its answer specifically assumes "this is not meant for production" :)
anrieff
  • 5,199
    Maybe a small amount of desiccant in the enclosure? – Ignacio Vazquez-Abrams Jul 10 '18 at 22:21
    Do you have a service life requirement? Does the box get opened to periodically to replace the batteries? – Jack B Jul 10 '18 at 22:21
  • If this isn't a situation where the customer needs to open the box and so you have control, I don't see a reason why dry nitrogen back-fill is an "expensive operation." What makes you think so? – jonk Jul 10 '18 at 22:23
  • @IgnacioVazquez-Abrams, this could work, but not in a "silica gel bag" form, it needs to be anchored (and customers will be curious/surprised if something rattles inside) – anrieff Jul 10 '18 at 22:34
  • @JackB, jonk - no, it won't be opened past manufacture. The nitrogen backfill ... I dunno, but doesn't it require having 1-2 additional holes in the box? Also having nitrogen at your disposal at all times? – anrieff Jul 10 '18 at 22:39
  • A small blob of gel desiccant on the inside of the enclosure. – Ignacio Vazquez-Abrams Jul 10 '18 at 22:44
    Or just use the low cost granular desiccant that comes in the small closed bags. These can be easily taped into desired places inside the enclosure using an inch square piece of double stick foam tape. Check on Amazon to see the wide range of sizes available and what kits of 100 or even 250 quantity cost. – Michael Karas Jul 10 '18 at 22:58
  • @anrieff - go look at the costs of renting a tank of nitrogen. Try a welding supply house. Amortize this over the number of fills you can get from a tank and you'll find it's pennies per unit. – WhatRoughBeast Jul 10 '18 at 23:08
  • @WhatRoughBeast - The cost has to include the extra ports on the enclosure used to extract the air and inject the N2 gas. If ports are not used the the unit final assembly was being simply done in an N2 rich environment then you need to consider the cost of the enclosure where the final assembly takes place. – Michael Karas Jul 10 '18 at 23:18
    Guys, please turn your comments into answers so that we can discuss comfortably on them – anrieff Jul 10 '18 at 23:27
  • @MichaelKaras - You bet. However, I was specifically referring to his "having nitrogen at your disposal at all times". It's just not that big a deal. – WhatRoughBeast Jul 11 '18 at 00:45
  • Perhaps hydrophobic coating on the display area is an extra precaution. Even if moisture does get in (it will) it won't stick to the display area. – Jeroen3 Jul 11 '18 at 10:04
Use silica desiccant
This is the stuff that often comes with clothes or moisture sensitive components in a little bag, often marked "do not eat" for some unfathomable reason. It's also used in some double glazing units to scavenge any moisture that does leak in, to avoid condensation.
Silica desiccant is cheap and is available in bulk, or pre-packaged in little permeable bags. You probably want the bag, and you can stick it somewhere out of the way inside the case with a dob of glue or double sided tape.
The desiccant will take up the moisture which is inside the box when it is sealed, and also any which leaks in over time. Eventually, it will saturate, and lose it's effectiveness, but if you use enough it will last a long time.
You can increase the life of the desiccant by minimising the moisture in the box when it is sealed. Warming the whole assembly, or blowing with warm dry air will help. Doing the final assembly in a small room with a dehumidifier running would be an option too. It will also last longer if the seal is good. Once the desiccant is saturated, it is possible to dry it out again in an oven, and it may be helpful to do so before putting it in the box, to make sure it hasn't got damp sitting on the shelf.
Jack B
  • 12,167
