I am trying to properly wire and then dim Cree LED tri-pods (3 LEDs on a disk).
The spec sheet appears to read that the way to connect 2 * tri-LED pods (6 individual LEDs in total) would be in series, incremented at 2.6v per pod (maybe LED). It is not clear about the pods at all.
Bench top test result only produce any light at all above 4v per tri-LED pod, with optimum at 7.8-10v in 'parallel' for two pods LED info
Also, you would think that dimming these LEDs would be via PWM but my benchtop potentiometer demonstrates that lowering voltage is the way you dimm these units.
1) Can someone explain these LEDs pods to me, their optimum voltage and proper dimming? I think my benchtop results tell the story, but I am very unsure.
2) With 7.8v being the calculated max, how bad is it to run them at 9v? There is a difference. I am sure there is some resistance in this circuit I am not factoring in.
brhans
  • 14,373
  • 49
boobie
The current is what controls the brightness of an LED. You need to control the current (somehow). One way to do this is to use a benchtop power supply with a constant current mode. This will allow you to vary the current and set it to a level at which the LED's will turn on. There is one gotcha, the LED will not turn on unless it meets a voltage threshold.
If the current goes beyond what the LED is rated for, it will overheat, and damage the LED.
Find the color of you LED module, then look it up on the table, you need at minimum that voltage. For a blue module, you need at least 3.1V at which it will draw 350mA. If you have a constant current supply, you could just set it to 350mA and it would find the voltage (which will be around 3.1V).
You need to limit the current, if you set it to 9V the LED's could draw a lot of current, even amps of current which may be too much (you can find out how much current is max for the LED in the datasheet for the color you have). That means you need to calculate both voltage and current if you have a resistor.
There are plenty of circuits to limit current or these besides a resistor
You cal also use PWM to dim the LED's, the rules still apply, you can't go over the maximum current limit.
Voltage Spike
  • 75,799
  • 80
  • 208
