I'm looking through a product design, and I've seen these SMD / sticky segmented displays LCD being used.
They are not hand-soldered, the segmented display appears to use some conductive sticky pad that attaches the pads on the board that have the common & signals going to the LCD.
Do you know what this is called specifically? I've used typical thru-hole segmented displays, and I see that you can get like half-hole module type displays.
Anyone know the term of display that you just stick on the board?
(The white part is actually the backlight, and then the LCD display just goes on top and connects to those rectangular vertical pads circled in red).
