I have this 5 V output SMPS I bought a while ago. I was wondering why there are LCRs connected to the input of my SMPS. I don't understand why it's there.
BTW, I'm an electrical engineering student, and I know the basics of LCR, but I am not sure what it's doing here.
Enter image description here
Peter Mortensen
  • 1,676
Aimkiller
  • 354
Generic image
The yellow thing is an X-capacitor, C11 in the above schematic. The resistor is to discharge said X-capacitor within legal requirements (usually 34 V within 1 second after unplugging), R14 in the schematic. L is an common mode choke, X3 in the schematic. They all form the EMI supression from the power supply to the mains, again within legal requirements.
Please see this old question for more information: X capacitor selection for SMPS power supply
Peter Mortensen
  • 1,676
winny
  • 13,064
  • 63
This is a filter that sits between the mains power line and the SMPS. Its goal is to suppress electromagnetic interference (EMI) and (to some extent) protect the circuit from spikes on the line. The basic structure of such a filter looks like this:
Line filter
These filters use specially-rated capacitors to handle the high AC voltage. The capacitors used between the hot and neutral lines (inputs 1 and 2, outputs 3 and 4) are called "X-class capacitors", or "X capacitors" for short. The capacitors used between a hot or neutral line and ground are called Y-class capacitors. The X and Y stuff is just a safety rating; it means the capacitors can survive the line conditions.
Also in the filter is a pair of coupled inductors which form a common-mode filter. This allows the differential line voltage through, but blocks any voltage spikes that are on both lines at once.
Adam Haun
  • 21,331
  • 50
  • 91
  • Thanks for you explanation. both answers explained it well for me. – Aimkiller Jun 28 '18 at 15:10
    The safety rating doesn't just mean the caps will survive the line conditions. It also means that if the cap is subjected to conditions it cannot survive, it will fail open rather than shorted. – supercat Jun 28 '18 at 23:46
