I realized an AES-256 algorithm which encrypts a 128-bit std_logic_vector (plain_text) with a 256-bit std_logic_vector (master_key). I made a test-bench in order to verify the behavior of the encryption process, and now I would like to implement this algorithm on my Basys3 board (I use Vivado as IDE). My questions are:
How can I map the input vectors? Should I declare signals in my architecture, knowing that I do not have enough I/O ports?
winny
  • 13,064
  • 63
Cedric
A serial interface uses the least amount of pins. From all the serial interfaces SPI is the easiest to implement. (I think it is about five lines of code). As an SPI interface streams data in and out at the same time you can also use it to read the result.
Ok, I just tried and it was a bit more then five lines mostly dealing with the synchronisation of the SPI signals to an (internal higher frequency) system clock.
The following code was quickly hacked together and seems to work:
// Simple dumb SPI interface:
// one big long shift register
// Relies on a system clock which is
// much faster then the SPI clock
// User MUST send the right amount of bits in one go.
module spi_dumb
#(parameter DW   = 128) // Number of internal data bits
    // Usual system signals
    input  clk,     // system clock
    input  reset_n, // system reset
    // SPI interface
    input  sclk,
    input  sel_n,
    input  mosi,
    output miso,
    // Internal data interface
    input      [DW-1:0] par_tx, // Data to transmit
    output reg [DW-1:0] par_rx, // Data received
    output reg          valid   // Data has arrived
reg  sclk_meta,sclk_sync,sclk_prev;
reg  seln_meta,seln_sync,seln_prev;
wire clock_edge;
//   assign clock_edge = ~sclk_prev &  sclk_sync; // Rising edge
   assign clock_edge =  sclk_prev & ~sclk_sync; // Falling edge
   always @(posedge clk or negedge reset_n)
   begin
      if (!reset_n)
      begin
         valid     <= 1'b0;
         sclk_meta <= 1'b0;
         sclk_sync <= 1'b0;
         sclk_prev <= 1'b0;
         seln_meta <= 1'b0;
         seln_sync <= 1'b0;
         seln_prev <= 1'b0;
      end
      else
      begin
         // Sychronise the clkc and select
         sclk_meta <= sclk;
         sclk_sync <= sclk_meta;
         sclk_prev <= sclk_sync;
         seln_meta <= sel_n;
         seln_sync <= seln_meta;
         seln_prev <= seln_sync;
         // On falling edge SPI-Select load the shift register
         if (seln_prev & ~seln_sync)
         begin
            par_rx <= par_tx;
            valid  <= 1'b0;
         end
         // On rising edge SPI-Select mark the data as valid
         if (~seln_prev & seln_sync)
            valid  <= 1'b1;
         // If SPI select is low and we have a clock edge pick up the data
         // We assume the mosi data is stable by then
         // (~Two system clocks after SPI clock edge)
         if (!seln_prev && clock_edge)
           par_rx <= {par_rx[DW-2:0],mosi};
      end
   end
   assign miso = par_rx[DW-1];
endmodule
 * Auto generated testbench, generated Wed Jun 20 11:04:23 2018
 * post edited
module spi_dumb_test;
localparam CLK_PERIOD=100;
localparam DW= 128;
reg           clk; // system clock
reg           reset_n; // system reset
    // SPI interface
reg           sclk;
reg           sel_n;
reg           mosi;
wire          miso;
reg  [DW-1:0] par_tx; // Data to transmit
wire [DW-1:0] par_rx; // Data received
wire          valid;
integer bit_count;
reg  [DW-1:0] master_tx; // Data to transmit
reg  [DW-1:0] master_rx; // Data received
   initial
   begin
      reset_n  = 1'b0;
    // SPI interface
      sclk     = 1'b0;
      sel_n    = 1'b1;
      mosi     = 1'b0;
      par_tx   = 'b0;
      #(5*CLK_PERIOD) reset_n=1'b1;
      #(5*CLK_PERIOD) sel_n = 1'b0;
      par_tx    = 128'h12345678_11111111_87654321_A5C33C5A;
      master_tx = 128'h23242526_34353637_45464748_56575859;
      for (bit_count=0; bit_count<128; bit_count=bit_count+1)
      begin
         #(5*CLK_PERIOD) ;
         // Tx & RX master emulation, MS bits first
         mosi = master_tx[DW-bit_count-1];
         master_rx[DW-bit_count-1] = miso;
         sclk = 1'b1;
         #(5*CLK_PERIOD) ;
         sclk = 1'b0;
      end
      #(5*CLK_PERIOD) ;
      sel_n = 1'b1;
      #(50*CLK_PERIOD) $stop;
   end
spi_dumb
   #( .DW (DW) ) // parameters
spi_dumb_0 (
      .clk    (clk),     // system clock
      .reset_n(reset_n), // system reset
    // SPI interface
      .sclk   (sclk),
      .sel_n  (sel_n),
      .mosi   (mosi),
      .miso   (miso),
      .par_tx (par_tx),  // Data to transmit
      .par_rx (par_rx),  // Data received
      .valid  (valid)
   // Generate clock.
   initial
   begin
      clk = 1'b0;
      forever
         #(CLK_PERIOD/2) clk = ~clk;
   end
endmodule
Post edit 2-7-18: found that begin end pair was missing.
Oldfart
  • 14,212
  • 41
  • This obviously shouldn't become a "compare all serial protocols" thread, but the reason I wouldn't advise SPI to beginners is because the world still hasn't decided on what *the* SPI protocol is. It'd work, but require more fiddling than other, more standardized protocols. Also: writing it the easy, terse way tends to lead to clock domain transitions. That all being said: +1, of course. – DonFusili Jun 20 '18 at 08:46
  • I started writing one and have updated my answer. I might post the code once it is verified. (Which takes 10x longer then writing the code) – Oldfart Jun 20 '18 at 09:00
  • Thank you very much, I appreciate your help. I will look for further information about SPI ! – Cedric Jun 20 '18 at 09:37
The Basys3 board has a USB to UART interface. Use this to implement a UART link with your computer. I haven't yet seen a computer running windows or Linux that doesn't support UART over COM/tty.
There are a number of open source UART cores, but I'd advise writing it yourself, most of them are not worth much and a UART isn't hard to write anyway.
(De)serializing is the same as filling/emptying a shift register over the UART.
DonFusili
  • 1,069
