So I'm looking into retrofitting a Qi transmit eval and receive eval kit with coils of a larger diameter than the stock ones, then looking at what playing with the separation will afford me for my theoretical use-case (I would be exceeding the recommended Qi 5mm max sep). To clarify, I understand I may be taking them out of the Qi specs for now and that's fine for the purpose of my study. Starting with this stack exchange discussions:
Is the QI norm about the components or the coil?
and
How big does my wireless charging coil need to be?
I thought I could in theory, take the field generated by the Tx'er Bt(z=0), then that received by the Rx'er Br(z), solve them for current, then take the ratio of received to transmitted current multiplied by the required voltage ratio and get the required power ratio to calculate efficiency. This would give me the variables of the separation of the coils 'z' and their associated radii directly influencing the efficiency (power ratio), but the numbers don't make sense. Have I made a gross oversimplification or is my logic not valid outright? Thanks in advance for any insight or any pointers on a direction I should go from here, b
