I have a Noctua NF-F12 computer fan (specs: https://noctua.at/en/nf-f12-pwm/specification). I also have a Samsung USB Wall Adapter (Originally for charging my tablet). The USB Wall Adapter says it can output 5V 2.0A.
My computer fan, according to the specs, runs at 12V 0.05A. How do I go about powering this? Some have said to purchase a 5V to 12V step up module with a USB connection, then solder the fan wires onto that, and plug the USB end into the wall adapter or would it work if I plugged it into a computer's USB port?
I've also seen DC wall adapters for sale. I saw a 12V DC Wall Adapter, and it says it can output 12V 100mA. However, most of them supply 500 mA, 1A, or 2A. My fan says it only needs 50 mA (0.05A). What happens if I solder the fan wires to this DC Wall Adapter? It is 12V but isn't it too much current? Will this burn out the fan?
Edit: With all that said, is it best to just purchase a DC power supply and splice the fan wires, or can I go with a 5V to 12V step-up module with a USB connection and use any of my USB wall chargers instead?
Thank you in advance.
