I need to build a Geiger counter power supply circuit that will provide a 400 V DC output out of one of those 6LR61 9 V batteries. I thought about using a 555 timer to produce a square wave, feed it into a 1:45 transformer and then filter out the output, but I have no idea about what frequency and how many primary and secondary windings to use, and whether it would work at all.
update:
OK, thanks everyone for your effort but I guess I'll just go with a 555 inverter circuit like this (sorry for the watermarks), with custom transformer and a filter on the output.
ocrdu
  • 8,705
  • 30
  • 42
That guy
  • Try TI webench for inspiration. – winny Jun 03 '18 at 09:24
    Thanks for the idea, but webench didn't find anything. The ratio is probably too high. – That guy Jun 03 '18 at 09:31
  • How much current does the counter need? For very low current, a modest transformer step-up followed by a cascade might be suitable. For higher power a flyback is a good choice. With a 6LR61 you're not going to be able to get much power anyway. – Neil_UK Jun 03 '18 at 09:35
  • The tube won't need much current, but the thing is that I don't posses the needed knowledge to calculate all the numbers, and I didn't find any close example of the power supply. – That guy Jun 03 '18 at 09:42
    @Thatguy good literature available: https://en.wikipedia.org/wiki/Voltage_multiplier – Marcus Müller Jun 03 '18 at 10:23
  • There is no upper limit of turns ratio. You can use powerelab’s poweresim and “wind” your own transformer there. Or just use webench as a starting point for some lower output voltage with COTS magnetics, copy the primary and increase the turns ratio in your final circuit. – winny Jun 03 '18 at 10:23
Here's a reputable one that runs from 5 volts and uses an inductor to get initial voltage magnification then a cockcroft-walton multiplier: -
Maxim article that gives more detail. Use a voltage regulator to drop the 9 volts to 5 volts and because you are using a battery I'd urge you to use a buck regulator to prolong battery life.
There is also this that runs from a 555 timer and uses an LT700 audio transformer: -
Full details here. But google really is your friend on this and you can find many images of circutis on-line.
