When I leave my favorite headphones connected to my favorite smartphone or laptop when I'm not currently playing any audio, I periodically hear a small pop/click/crackle. I suspect it happens when some process "opens the headphone port", even if they don't immediately start playing audio.
Please note that I don't get any pop/click/crackle at other times, no matter how much I rotate or wiggle the plug or cord; so I have no reason to suspect flaky connections of any kind, such as dirty connectors, broken wires, etc.
I saw this answer to a similar question…
Loud pop noise while plugging to a headphones jack
…and I wonder if that applies to my situation.
I'm wondering if the small pop I hear might have the same root cause (charging a DC decoupling capacitor). I'm also wondering if I could implement the proposed solution — wiring a ~100Ω resistor from line to ground — in an external dongle I would place inline between my headphone cord and my audio source device.
Spiff
  • 103
You've missed the grand fallacy of this idea: there is already a much more significant 8 to 32 Ω across the output if the headphones are already plugged in. The 1000 Ω in parallel won't make any difference.
Figure 1. The problem this time is that the amplifier or pre-amplifier is being enabled in the device hardware.
On turn-on the amplifier output jumps to V+/2 and so does the right side of C1 until discharged by the speaker. The pulse is what you hear.
Sorry, I don't have a solution for you.
Transistor
  • 168,990
  • 186
  • 385
    best solution is to unplug when not listening. – danmcb May 31 '18 at 21:41
  • That creates the problem in [the question linked by the OP](https://electronics.stackexchange.com/questions/323356/loud-pop-noise-while-plugging-to-a-headphones-jack/323360#323360). Also, the point is that s/he *is* listening but there has been a gap for whatever reason. – Transistor May 31 '18 at 21:58
