Is it okay to replace my worn li-polymer 3.8v and 2200maH battery with a li-ion battery with 3.7v and same 2200maH capacity?Will the 0.1v be of any harm to the delicate electronics of the phone?
MarkU
  • 14,413
  • 53
David Teahay
  • 101
Charging voltage for the newer Li-Po cells is usually 4.35 V. When you use an older Li-Ion cells in modern phone, the battery standard charge level of 4.20V will be exceeded substanially. It might be OK to charge a 4.2V battery with 4.35 V levels, but battery cycle life will be decreased about 3-4-fold, as this example shows.
But before worry about all this, check the actual charging voltage on your phone, maybe it is just 4.2 V standard.
Ale..chenski
  • 38,845
  • 38
  • 103
  • With all the questions regarding battery swapping Do you know if there is a reference question that could be a generic answer to most common questions (safety, charging caracteristics, etc...)? – Simon Marcoux May 15 '18 at 01:18
  • 4.35 V is LiFePO₄ (aka lithium iron phosphate). LiPo is lithium-polymer, which is just a way of manufacturing the cell; there's nothing special about its chemistry. It's 4.2 V just like standard non-polymer li-ions. – Hearth Dec 14 '19 at 21:06
