I am building a small battery backup for my router with the 12V 0.5A DC input. Main use is to keep the router powered up during load shedding (aka. power cuts / blackouts ) while my backup generator is being switched on.
This is what I'm thinking of using:
schematics
Explanation:
  1. Two Li-ion 18650's in parallel
  2. TP4056 charge and discharge protection board connected to input and outputs of the cells. the output from this will be 3.6v ( the interfacing taken from here )
  3. MT3608 boost converter - configured to step up 3.6 v to 12v which is fed to router
Will this setup work for the following objectives?
  1. Safely power router in normal use
  2. During blackouts, keep router running with no downtime.
  3. Li-on battery does not explode and lasts 1-2 years (I am most confused about this since the batteries will always be plugged into the charging circuit)
EDIT (Clarifying)
Duration of a blackout is not an issue since the backup generator provides power. In between the blackout occurring and the generator switching on, there is a small delay - around 5 minutes. It takes 3-5 minute for the router to function normally after reboot. This is an issue when there are alternating blackouts every 30 minutes.
animus
    This is a bad idea in many ways, and especially when the data sheets have not been read. The LM2596 is a buck regulator, not a boost converter. There are 12 battery backup systems available for purchase. – Chris Stratton May 05 '18 at 15:28
  • Regarding objective #2: How long do you expect a blackout to last? You'll also want some over-dishcharge protection on the lithium cells and ensure they can provide the required current. – tangrs May 05 '18 at 15:34
  • Sorry about that, just checked my links again. The component I meant to use was MT3608. changed the question and schematic. – animus May 05 '18 at 15:38
  • @tangrs the duration of blackouts is not an issue since the backup generator provides power. In between the blackout occurring and the generator switching on, there is a small delay. I want to cut the 3-5 minute reboot time of the router. This is an issue when there are alternating blackouts every 30 minutes. – animus May 05 '18 at 15:44
Step up converter
Assuming peak load, your router will be drawing \$12V*0.5A=6W\$ of power. At 80% efficiency, your step-up converter will draw \$\frac{6W}{0.8}=7.5W\$ at its input. This means your 2 lithium cells will need to be able to provide \$\approx1A\$ each (\$\frac{7.5W}{3.6V}=2.08A\$). You don't specify which 18650 cells you plan to use so I can't say whether you can safely discharge that amount of current from it.
Battery charging
Your TP4056 is only capable of delivering \$1A\$ of current on the output. Since the step-up converter draws \$\approx 2A\$ during peak load (as calculated above), this will mean that the batteries will actually be discharging during peak load. Whether this is a problem depends on the average power consumption of the router and how long the periods of peak power consumption are.
USB charger
Lastly, your USB charger is only capable of putting out \$5V*1.5A=7.5W\$. Assuming your battery charging circuitry is less than 100% efficient, this is not enough to power your router at peak load. However, in this case, your peak load tolerance is limited by the TP4056, rather than the USB charger. If you decide to upgrade to a beefier battery charging circuit, your USB charger is going to be a bottleneck.
Lithium-ion batteries
Li-ion batteries don't like to be fully discharged. Depending on the nature of the circuit and how the batteries are discharged, it can lead to the battery catching fire or exploding when it is recharged again. Your 18650 batteries likely do not come with over-discharge protection circuitry so you should also factor this in. Edit: It appears the TP4056 has built-in over-discharging protection if you use the OUT terminals.
You also don't mention how long you'd like the batteries to last during a blackout. Based on your comment, I'm assuming you just need runtimes measured in the order of minutes.
Assuming peak current draw and you want the battery to last at least 5 minutes, your total battery capacity needs to be larger than \$2A*\frac{5}{60}=167mAh\$ (keep in mind the C rating needs to be large enough to carry the amount of current needed by the step-up converter as calculated above).
Objectives
To answer your questions:
  1. Will this power your router in normal use? As mentioned above, it depends on what 'normal use' is. You only specify peak current consumption which is not enough to answer this question.
  2. If you size your battery correctly, this should be possible as mentioned above.
  3. If you select high quality cells with decent protection circuits and follow best practices, lithium cells should be fine to use. Obviously, this being a home-made project, there's no guarantees.
tangrs
  • 1,029
  • About 'Normal' use - When the power is on, and batteries are already charged, there will be no discharging happening (I assume. Please correct me if not). That's what I meant by normal use. – animus May 05 '18 at 16:33
  • I'm more talking about the average power consumption of the router during 'normal use'. – tangrs May 06 '18 at 01:56
  • Just designing with max load in mind, this answers my question – animus May 06 '18 at 07:04
