I see this question on EE but the other question is slightly different of what I am asking.
Suppose this circuit:
Suppose I will add a capacitor to the input but I need to calculate the input impedance of the circuit on the picture.
Suppose the impedance was fixed for all frequencies. If I understand correctly, if the impedance could be measured by a multimeter it would be the "resistance" measured from the point IN to ground, right?
If this is true, it would be R2 in parallel with the sum of rEE and Re, or in other words
Rin = rEE + Re
where rEE is the base/emitter resistance (25mV/Ie), right?
Then, if that transistor is biased at 1mA,
rEE = 25mV/1mA = 25Ω.
So, if R1 = 20kΩ, R2 = 2.7kΩ, Rc = 3.9KΩ and Re = 470Ω
So Rin = 2700 // (25 + 470), that would be 418.3Ω...
but I have found one author saying Rin is in fact equal to βrEE and does not even include Re.
... and now I have found a post on EE showing a very complex formula that takes into consideration R1, R2, Re and other components.
What is really the impedance of such circuit?
Duck
  • 787
  • To be more precise because Ie = (hfe + 1)*Ib hence Rin = R1||R2||[(hfe+1)*(Re + ree)] – G36 May 04 '18 at 19:28
    I think it is one thing to ask about a DC multimeter measurement from the base node to ground. (Would you first connect Vcc to ground, too, or just leave it floating?) And a different thing to talk about the AC impedance for a signal passing through a capacitor to the base node with power applied to the circuit. So perhaps you are conflating several different ideas and may need to first work on recognizing differences. – jonk May 04 '18 at 19:56
  • ok but in my case I do not have an input capacitor, not yet. This is why I need to calculate the input impedance of the transistor circuit, so I can calculate the capacitor I will add to the input. – Duck May 04 '18 at 20:07
  • @SpaceDog Then you are NOT talking about the case of applying a DC multimeter to measure things from base to ground. You want the AC impedance. Probably should remove the "multimeter" part of your question, to help clarify. Now that this is clear, there is another problem. You write, "Suppose the impedance was fixed for all frequencies." But that is not true for capacitors or inductors. If you want to size the capacitor, you will need to have a "lowest frequency" you care about. Also, if you are using high frequencies, parasitics will matter a lot more. – jonk May 04 '18 at 20:15
  • ok, I see. All I need in this case, is to calculate the input capacitor. In that case I need to know the input impedance. Suppose the cut off frequency f is 20 Hz. So, in order to use the formula C = 1/2.pi.f.Rin, I have all variables except Rin... this is my problem. :( – Duck May 04 '18 at 20:34
  • But what is your problem? The exact calculation and are not needed and unnecessary. Mainly due to component tolerance we are using. For example, for Ie =1mA we will have ree = 25Ω and if hfe = 100; RE = 220Ω; R1 = 22kΩ ; R2 = 4.7kΩ the Cin = 1/2.pi.f.Rin =(1 / 2 * pi * 20Hz * 22k||4.7k||[(100+1)*(220R + 25R)] ) = 2.37uF so you need to use 2.2uF capacitor or 3.3uF (but 3.3uF is preferd value). And you will get almost the same capacitor value if you would use a simplified equation C = 0.16/(20Hz * R1||R2||(100*220R)) = 0.16/(20Hz * 3.3k) = 2.4uF – G36 May 04 '18 at 20:58
  • @G36 You may want the input capacitor to present only 10% or less of the input impedance. Perhaps not equal to it. If equal, then the divider will be significantly frequency-dependent. – jonk May 04 '18 at 21:50
I think you've sufficiently gathered up the idea that this isn't a multimeter question, but one of what things look like from the point of view of small signals that attempt to wiggle the base of the BJT through a capacitor.
It's one thing to be just told an equation. It's another to understand why. I'll try to add the why-parts here.
The input capacitor is said to block DC. But another way to look at it is to simply imagine that when a circuit powers up, it doesn't take too long for the input capacitor to develop some voltage across it. If there is no signal, this voltage is fixed by the DC operating point of the circuit before it and the circuit after it.
For example, you might have a \$5\:\text{V}\$ difference between the output that is driving this input capacitor and the voltage that develops at the base of the BJT in the circuit that follows this input capacitor.
Now, when an AC wiggle occurs from the input side of the capacitor, the voltage across the capacitor acts (if designed correctly) very much like a \$5\:\text{V}\$ battery. So the base of the BJT simply moves up and down in concert, separated only by this voltage difference. In short, the capacitor allows the signal source to have a different DC biasing point than the BJT biasing point of this circuit by simply charging up to the difference between them. It could be a big difference or a small difference. It could be polarized one way or polarized the other way. It doesn't matter. It simply charges up.
(Of course, hopefully, you know which end is "up" if you control both circuits. Otherwise, if you don't know the DC bias of the input source relative to the DC bias of your BJT circuit, you may need to use a non-polarized capacitor.)
Now, it's true that there will be some loading on this input capacitor due to the BJT circuit. And this will cause the (\$5\:\text{V}\$?) voltage difference across the input capacitor to start to change. But the whole idea here is to make the capacitor large enough so that the voltage difference doesn't change much over very short periods and, in all cases, will on-average remain where it started over very long periods.
Also, the input capacitor is a frequency-dependent device. It's impedance varies with frequency. The total input resistance of the BJT circuit acts like a voltage divider in concert with the input capacitor (and any other input source impedances, too.) Since the input capacitor's impedance varies widely over the range of desired frequencies you want to support (let's say, from \$20\:\text{Hz}\$ to \$20\:\text{kHz}\$, or three orders of magnitude), you want the capacitor's impedance, which varies over a range of 1:1000 here, to always be low compared to the CE BJT stage's input impedance. If it isn't always low by comparison, then you will have a significant frequency-dependent variation in the loss of signal prior to being amplified by the BJT circuit. This means a significantly variable gain vs frequency. That may, or may not, be important to you. If there is global negative feedback taking place, this may be acceptable to you. But as a stand-alone concept, frequency-dependent gain is not so good. So you want the impedance of the capacitor to be relatively small, in the worst case of your lowest frequency of interest, when compared to the input impedance of the BJT amplifier circuit. A figure of 10% is okay, as this just means 10%...0.01% vs the input impedance of the amplifier. So the divider will provide a frequency-dependent signal of from 90% to 100% at the input and that is an easily acceptable variation.
Enough said about the input capacitor.
For the impedance seen by the capacitor as a load caused by the BJT amplifier circuit, you can easily just imagine the fact that \$R_1\$ has one end nailed to a voltage source and that \$R_2\$ also has one end nailed to a different voltage source (ground), so the input capacitor has to treat those two resistors as if they were in parallel. They both have to be "driven" and they are both tied on their other ends to rock-solid voltages. So they are "parallel" in every meaningful way.
In addition, you have the base of the BJT. For this, you have two things operating. One is just \$R_\text{E}\$ itself. But to change the current in \$R_\text{E}\$ by \$1\:\text{mA}\$ you only have to change the base current by about \$\frac{1}{\beta+1}\$ of that emitter current change. So this fact alone means that \$R_E\$ looks like a resistor of \$\left(\beta+1\right)\:R_\text{E}\$. (Of course, the other end of \$R_\text{E}\$ is also tied to a solid voltage.)
Plus, there is one more detail. The dynamic resistance of the Ebers-Moll equation for the active-mode BJT (assuming the emission coefficient is 1, as it usually is.)
$$I_\text{C}=I_\text{SAT}\cdot\left(e^\frac{V_\text{BE}}{V_T}-1\right)$$
The dynamic resistance is found by:
$$\begin{align*} I_\text{C}&=I_\text{SAT}\cdot\left(e^\frac{V_\text{BE}}{V_T}-1\right)\\\\ \text{d}\:I_\text{C}&=\frac{I_\text{SAT}\cdot e^\frac{V_\text{BE}}{V_T}}{V_T}\:\text{d}\:V_\text{BE}\\&\therefore\\\frac{\text{d}\:V_\text{BE}}{\text{d}\:I_\text{C}}&=\frac{V_T}{I_\text{SAT}\cdot e^\frac{V_\text{BE}}{V_T}}\approx\frac{V_T}{I_\text{C}} \end{align*}$$
Mapped to the emitter, it is:
$$r_e=\frac{\text{d}\:V_\text{BE}}{\text{d}\:I_\text{E}}\approx\frac{V_T}{I_\text{E}}$$
That value of \$r_e\$ is added to \$R_E\$ before being mapped backwards to the base by using \$\beta+1\$, so the total impedance (discounting other unmentioned details) seen at the base node is:
$$R_1\mid\mid R_2\mid\mid\left[\left(\beta+1\right)\cdot\left(R_\text{E}+r_e\right)\right]$$
Above, when computing \$r_e\$, \$I_\text{E}\$ is often taken as the quiescent value. It will vary somewhat while the BJT amplifier operates and the collector and emitter currents change. So the actual input impedance will also vary a bit. But if \$r_e\ll R_\text{E}\$ then the impedance will be relatively stable. And this would also mean we can ignore it, too, if true. So the impedance is often based on the idea that \$R_\text{E}\gg r_e \$ so that the expression above can be simplified to:
$$R_1\mid\mid R_2\mid\mid\left[\left(\beta+1\right)\cdot R_\text{E}\right]$$
And if \$\beta\gg 1\$ then still simpler:
$$R_1\mid\mid R_2\mid\mid\left[\beta\cdot R_\text{E}\right]$$
So, assuming \$\beta\gg 1\$ and \$R_\text{E}\gg r_e \$, you will want:
$$X_C\ll R_1\mid\mid R_2\mid\mid\left[\beta\cdot R_\text{E}\right]$$
or,
$$C \gg \frac{1}{2\pi\: f\: \left(R_1\mid\mid R_2\mid\mid\left[\beta\cdot R_\text{E}\right]\right)} $$
A factor of 10 or more would be sufficient to qualify, so:
$$C_\text{IN} \approx \frac{1.6}{f_\text{LOW}\: \left(R_1\mid\mid R_2\mid\mid\left[\beta\: R_\text{E}\right]\right)} $$
jonk
  • 77,059
  • 73
  • 185
First approximation: R1 // R2 // Re*HFE
for Re>>REE
Why Re*HFE?
The emitter is a voltage follower, which means Vbase is "across" Re. But because of current gain we only need 1/HFE the current to make that happen, so R must be Re*HFE
Henry Crun
  • 5,273
  • The quantity ree=1/gm (gm: transconductance) is NOT a resistance and - in particular - not a STATIC resisistor and, therefore, must not be written as REE. It is essential in electronics to distinguish between static and dynamic resistances. – LvW May 04 '18 at 19:34
  • I do not understand why R1 is put into the equation... – Duck May 04 '18 at 19:43
  • R1 is connected to an AC ground point: VCC. So it is an AC impedance to ground in // with R2 and the base – Henry Crun May 04 '18 at 19:46
  • do you mean that the power supply is a "short circuit" for AC signals? Interesting... – Duck May 04 '18 at 20:06
  • you say R1 // R2 // Re*HFE but shouldn't rEE be considered too? R1 // R2 // (Re + rEE)*HFE? I don't get your last paragraph... sorry I am newbie. – Duck May 04 '18 at 20:11
  • The word I used was "approximation" . 25 ohms is seldom significant, so I don't need to consider it. An engineer is a man who knows that 2+2 is close enough to 4 – Henry Crun May 04 '18 at 23:12
  • The power supply is rather assumed to be a short circuit for everything the circuit is going to throw at it. To ensure that, we put fat capacitors and little capacitors, both, across it. – Henry Crun May 04 '18 at 23:16
