Yes,i have seen all those similar questions of this topic and I am still confused about few concepts.So far i have been taught that an simplified OP-AMP circuit looks like this-------------- enter image description here
So,thinking about input bias current in that circuit here are some confusions-------
1)In a Youtube video i was told that input bias current enters/leaves from both inverting and non-inverting terminal at the same time...and they are equal,How?
2)In an OP-AMP datasheet we have only one value of Input bias current----enter image description here
But what if the source voltage changes along with the source resistance in that term the bias current also has to change(Below is my note,about what i mean to say)-----
So,we should have different values of input bias current but why only 1 value of input bias current is given in the datasheet?
Paran
  • 470
    Your note is not possible to find on google, which is one of the main points of this website - easy to search. Could you transcribe it to text instead? – pipe Apr 18 '18 at 09:37
Bias current is the typical/max current that can be assumed to flow at both input terminals.
Offset current is the typical/max difference in the bias currents.
When multiplied by any series resistor on inputs, bias current gives you the typical/max voltage that each input might settle to due to its bias current.
If an opamp has a large resistor between output and -ve input, and the same value resistor from ground to +ve input to compensate, then the offset current times that resistor value gives you the typical/max output voltage to expect from the imbalance in bias currents.
Neil_UK
  • 158,152
  • 173
  • 387
