I purchased a Xiaomi laptop PRO computer, which uses a USB-C plug for its power input. I recently measured the plug's shell with a AC voltmeter, and found to my surprise a voltage between 90 to 100 volts (AC)! May be that's why I always felt the sting of a slight electrical shock every time I used the computer. I understand the shell is used for signal shielding and therefore should not be carrying any voltage. Why then is there a voltage? How can I get rid of it? Was this a design or manufacturing error? (The other end of the USB-C cable is connected to a 2 prong non-grounded 60W transformer plugged into the wall.)
ahchoooo
    To what other point have you measured that voltage? If this weren't for safety reasons I'd vote to close this (the use of electronics is not on-topic) and your question is ill-formatted making it hard to read. My guess is that all is fine as your laptop would probably have some issues with AC in it. – Arsenal Apr 12 '18 at 15:19
  • What is the source impedance of this ~90VAC signal? – Voltage Spike Apr 12 '18 at 16:19
  • This is the usual thing, leakage. It is normally accepted and should be within regulation normative, see this topic as well, https://electronics.stackexchange.com/q/267146/117785 See also this, https://electronics.stackexchange.com/a/265375/117785 – Ale..chenski Apr 12 '18 at 17:48
It's from an interference suppression capacitor between the shell and the mains AC. The capacitor provides a path for high frequency noise to be shunted to the power supply, but it also allows a tiny amount of current to pass through it. Because your multimeter is very high impedance, it registers as a high voltage, but if you connect it to something the voltage will drop a lot. Your observation of a slight electric shock fits with this as the capacitor won't allow enough current to provide more than a slight tingle.
C_Elegans
  • 2,871
