I am programming a mbed LPC1768 for a constant current discharger. I plan to use the DAC output on the LPC1768 for setting the current in my discharge circuit.
edit: The trouble i am having is related to the voltage from the DAC during start and reset. I already made and tested the discharge circuit and it's NOT connected at the moment. At the moment i only have Rpulldown connected on the DAC and am viewing the DAC output on my scope.
I noticed that under start and reset the uC DAC goes to around 2V for a very short time. I guess it goes to some state untill i define the output in my code, but im not sure of it. edit: how do people usually deal with this kind of problem?
In my circuit these 2V is equal to 20A of discharge current. I dont want this to happen!
I tried pulling the DAC down with a 1K resistor and it sure clamps the DAC on start (goes to around 50mV on reset), but it also pulls the analog voltage down from what its set at in my code. Also tried 12K but that was not enough to clamp the DAC.
I have some different solutions to this problem, but they all involve transistors or relays. I was thinking there must be a more elegant way to deal with a problem like this and i can't be the first to have such a problem.
Can you guys please give me some tips on how to solve this problem? Should the DAC behave like this or am i doing something wrong?
Many thanks in advance!
Edit: added schematic, cleared up some confusing text.
Edit: This is how i am currently dealing with this problem. Any problems doing it like this or is it acceptable? It works but to me it seems a bit like a cowboy solution :)
Base is held high by a pullup resistor and this closes the relay loading the DAC output with 1K and pulling it to gnd. When enable is pulled low in my code the relay opens ands the DAC funtions as supposed.
edit: some code i tried running. just cycles the DAC between 0 and 3.3V. When i push / hold the reset button the DAC exhibits the behavior im talking about.
#include "mbed.h"
AnalogOut out(p18);
int main()
    out = 0;
    while(1)
    out = 1;
    wait(1);
    out=0;
    wait(1);
edit: added scope capture of glitch.
Only DAC output on start, no load attached:
With 10K across DAC:
With 10K across DAC
With 1K across DAC:
With 1K across DAC
1K across DAC, running a program that should toggle DAC between 0-3.3V. Goes to 3.3 with no / lighter load:
1K across DAC, running a program that should toggle DAC between 0-3.3V. Goes to 3.3 with no / lighter load.
Swagministeren
  • 241
  • What DAC are you using? – Billy Kalfus Apr 04 '18 at 14:13
  • Welcome to the site. Please can you edit your question to show a schematic (not a block diagram). The schematic editor here is a breeze to use. The better the quality of question, the better the quality of the answers you will attract. Again, a warm welcome to the site. – TonyM Apr 04 '18 at 14:13
  • @BillyKalfus, I imagine it's the DAC in the LPC1768 but the post isn't clear. The circuit of the current regulator it drives is a mystery, too. Hopefully, OP will clear all this up by posting a schematic shortly. – TonyM Apr 04 '18 at 14:15
  • The schematic is to be useful to the readers rather than yourself. Otherwise, people have to piece it together in their heads. The better the quality of question, the better the quality of the answers you will attract. – TonyM Apr 04 '18 at 14:43
  • Which DAC output pin? Does it have any alternate functions which might be active at boot? Show the code you use to configure it for use as a DAC. – Chris Stratton Apr 04 '18 at 15:58
  • Do you have access to a P channel JFET? If so, I have a solution. – Peter Smith Apr 04 '18 at 16:22
  • Please edit your question and add part numbers to your schematic. – TonyM Apr 04 '18 at 16:49
  • Chris: Its pin 18. It only has one DAC. – Swagministeren Apr 04 '18 at 19:27
  • TonyM: I don't know what more to add?! And why do i need to put part numbers on a circuit that isn't even connected yet. I only have a resistor connected across the DAC – Swagministeren Apr 04 '18 at 19:28
  • What voltage reference do you use for DAC? – Dorian Apr 04 '18 at 20:00
  • I'd try 4k7 as a pulldown, the DAC should be able to drive that much current. – Turbo J Apr 04 '18 at 21:14
  • The relay protection should be turned upside down, use relay with normal closed contact, pull down resistor for Q base and enable active high. As you made-it there is a delay from power up until the relay contact closes. The weak pull-up will not count against 1K resistors from Q base – Dorian Apr 05 '18 at 14:29
  • By the way , why don't you keep this and connect the Q collector straight to DAC output without DAC resistor or relay? The simulation shows 6mV saturation voltage while on? – Dorian Apr 05 '18 at 14:54
  • I use this relay because i had some lying around, but you are right it would be better to use a NC relay. Are you suggesting just clamping the DAC directly with the transistor? I dont know why i did not try that. Will give it a shot tommorow. I'm just not sure if i can pull it directly to gnd without a resistor? – Swagministeren Apr 05 '18 at 15:11
  • Why not? The I wasn't sure and I made a simulation with CircuitLab. Seems pretty reliable, on different values you have below 3 to 7 mV on DAC input while protection is active. – Dorian Apr 05 '18 at 15:36
  • I mean of course i can pull it to the gnd, but im not sure if the DAC is okay with being shorted. :) – Swagministeren Apr 05 '18 at 15:42
  • Right. Put the 1k resistor between colector and DAC. For a lower glitch move OA input to Q collector to. – Dorian Apr 05 '18 at 16:05
  • I don'tink is any danger if you release Q then quick set the dac to output. – Dorian Apr 05 '18 at 17:56
  • Apart from the solution semething still doesn't mach here. Why do you still have 2V with 12k load? Even in the worst case it sould be much less. Do you use a bootloader or something? Is there some read/modify/write operation happening at boot before your code? – Dorian Apr 06 '18 at 12:43
  • Im just programming it the way youre supposed to(i think). Write code, compile and drag and drop the file onto the LPC1768. I havent messed with anything, just writing code like this. The code im running has been added in the question – Swagministeren Apr 08 '18 at 11:46
  • After a google search I found this post https://community.arm.com/tools/f/discussions/873/boot-rom-question-of-nxp-lpc17xx on arm community forum , see the last reply: "The flash boot loader code is executed every time the part is powered on or reset." This is the price you need to pay for magic ready to run solutions, many things are happening behind your back before you actually run your code. Tough, if you have other peripherals needing a known state at start-up you could use the same ENABLE output for them to. – Dorian Apr 10 '18 at 08:07
During a reset, such as on power-up, your LPC1768 I/O ports will be configured as GPIOs in input mode. An LPC1768 I/O pin can output up to 3 uA of leakage current in this mode. When configured as a DAC, the same pin is specified as capable of driving a load resistance of 1 K or higher.
You don't specify your op-amp so let's assume that has an input leakage current of 2 uA. (You can readily find alternative op-amps with much less input leakage than this if yours is higher.)
This leakage current will be conducted to 0 V by your pull-down resistor and will produce a voltage drop across it, following V = IR. This voltage will drive your op-amp input during reset, until your software has configured your I/O for DAC operation, so the resistor voltage drop needs to be acceptably low. However, the resistor value should ideally be well above 1 K.
As an example, let's consider a resistor voltage of 20 mV. This corresponds to your op-amp driving 2 mA through your current regulator, assuming perfect accuracy there.
Then R = V/I = .02/0.000005 = 4000 ohms (a 3K9 resistor).
After reset, your software should configure the DAC while leaving the I/O pin in its initial state, as a GPIO input. Once the DAC is in the correct mode and set to zero, the GPIO can be configured as a DAC output. The I/O pin's optional pull-up resistor must not be used.
FURTHER FINDINGS...
From the LPC1768 user manual (UM10360), I didn't think the I/O pin pull-ups are enabled after reset. However, @Dorian has found information in the errata that states that they are.
Therefore, instead of the above, you can use an external defeat circuit to clamp the op-amp input to 0 V until the LPC1768 is stable and ready to drive its ADC output.
Choose a suitable logic-level FET for Q1 that is ON with a Vgs of 3 V or ideally down to Vgs of 2.7 V.
On power-up, GPIO will be internally pulled high but it also pulled high by R2, which is added for certainty after the errata affair. Q2 will conduct and short R1 to deck, ensuring that the op-amp input is zero. Once your software is up and running, it first configures GPIO/DAC to be a DAC driving 0 V. It can then configure GPIO to be an output driving low, turning off Q2 and allowing the op-amp circuit to work normally.
TonyM
  • 21,742
  • 39
  • 62
  • I will look more into this tommorow.You may be on to something – Swagministeren Apr 04 '18 at 19:34
  • Do i get this right? During startup i have to deal with 3uA of current and this should develop some voltage over the pulldown resistor? If i load the DAC with 1K i get 50mV. Should it not be 3u * 1K = 3mV. – Swagministeren Apr 05 '18 at 13:11
  • @Swagministeren, you're ignoring the leakage from your op-amp, plus the behaviour of your software - have another read of it. – TonyM Apr 05 '18 at 13:20
  • The opamp is not connected yet – Swagministeren Apr 05 '18 at 13:29
  • What i don't understand is. How can it be related to my code? It's happening during resets, i don't think my code is being executed in that time... – Swagministeren Apr 05 '18 at 13:31
  • At 3.3V Q1 does not cut the spike. – Dorian Apr 10 '18 at 17:08
  • @Dorian, can you give a much longer explanation than these one-line remarks please. There's absolutely nothing to go on there. How do you know, what was measured, what circumstances etc. – TonyM Apr 10 '18 at 17:50
  • I'm sorry, I was impolite. The simulation in CircuitLab shows that for GPIO voltage of 3.3V Q1 is not open enough to cut the spike. I don't remember the numbers and I'm om mobile now. Just make a DC sweep with GPIO DAC = 2V and GPIO 0 to 3.3V and see. Same thing happens to Peter, his transistor stays still open cutting the DAC output when it shouldn't. It's a FET thing working in the linear region. – Dorian Apr 10 '18 at 18:20
  • @Dorian, thanks very much for the detail. Sounds like the wrong FET then. Which one is OP using, which one are you modeling? – TonyM Apr 10 '18 at 21:20
  • I didn't noticed which one was. I just placed sources on your schematic and made the DC sweep but few are switching on compleetly at 3.3V gate voltage. – Dorian Apr 10 '18 at 22:37
  • Hi, after passing through many transistor models it seems that a low V_TO voltage transistor can do the job well. Raising both GPIO DAC and GPIO from 0 to 3.3V as on powerup shows a 800mv spike at 800mv GPIO/DAC voltage but that happens with bipolar transistor to. The lowest V_TO found in the list was FDN337. I will check again Peter's schematic to. – Dorian Apr 11 '18 at 09:08
  • @Dorian, have you tried an FDV301N or similar? – TonyM Apr 12 '18 at 22:39
  • @TonyM FDV301N is not on the list but with some parameters from the datasheet works. In fact any model with V cutoff less than 2.8V showed less than 20mV spike for GPIO = 3.3V, FDV301N has Vcutoff 0.5V, RDSon is higher than the model (5 ohm instead 0.1) but it makes no difference. – Dorian Apr 13 '18 at 08:54
The schematic below takes advantage of the fact that a JFET with gate tied to source is a low impedance. If you make sure that the ENABLE is not taken high until your DAC output is stable, then the MOSFET will be held off because the input to the amplifier will be held close to 0V.
Update to address comment: A JFET with gate tied to source (even through a resistor) is a low impedance when unpowered (effectively), so the circuit starts up with a low impedance at amplifier input.
When you take ENABLE high, the JFET becomes a high impedance and is effectively out of circuit.
Peter Smith
  • 21,923
  • 64
"If everything else fails then read the datasheet" and the errata to I might add. See the errata sheet for LPC1768 page 19: "The General Purpose I/O (GPIO) pins have configurable pull-up/pull-down resistors where the pins are pulled up to the VDD level by default. During power-up, an unexpected glitch (low pulse) could occur on the port pins as the VDD supply ramps up."
They mean the internal pull-up resistors of ~100k which is consistent with your observations: 50 mV for 1K pull down resistor and I just can guess a ~500 mV for 10K resistor.
Bad chip design I might say.
What to do ?
  1. One option is based on the assumption that all I/O are behaving in the same way and use a transistor like in Peter Smith solution. Still, this is subject to hazard If I understand well the meaning of "could occur". Shorter glitches still "could occur"
  2. A second option if you don't need quick variations on Iout is to place an RC filter to smooth the glitch like this:
With these values, 10 ms startup time, the glitch will be less than
50mV. R1 is there just as protection for an accidental digital
output setting for the pin.
3. A third option related to Peter Smith solution is to use an OA with shutdown input like OPA211
In any solution you choose it's a good practice to limit by hardware the damages that can by done by software errors and here I can suggest two options:
  1. Place a power resistor on the mosfet drain. Let's say your lowest battery voltage is 5V maximum 10V and the maximum current is 4A then place a 1 ohm resistor, the current will newer go above 10A no matter you do with the DAC output or enable output. I strongly recommend you to use that for the development stage.
  2. Set the DAC reference as high as possible and use the maximum range available as so the max DAC output will be as close as possible to the voltage that can be accidentally applied then use a resistive divider to bring the voltage in the range you need.
Let's say the max DAC output is now 0.5V for 5A max output. If by mistake the DAC output goes to 5V you will have 50A at least R1 will burn in flames.
If the max DAC output would be 3V, divided with a 6:1 resistor divider to 0.5V then an accidental 5V applied on DAC output will output only 5*5/3 ~8A , not a disaster, you have time to take action before something burns. In addition the startup glitch is also is divided six times.
simulate this circuit
Resistor values are not critical you can make some adjustments in software
Bonus: how to make a micro-controller design flaw even worse than it is.
You might think that you power on the board, change the pin to DAC and ready! How much time this can take on a processor that can run at 100MHZ? Microseconds? Wrong answer. I don't had time to read the all LPC1768 documentation but here is the worst nightmare that happened to me:
  • Power on, your DAC output is already high, wait for reset release some ms.
  • The microcontroller starts with the low power 32 khz clock
  • It runs the compiler generated code to initialize the variables and arrays if you not specifically told him not to do so. At 32 kHz clock it might take a loooong time.
  • Finally you get the control, change the system clock to high speed, wait for change. It might take some ms to.
  • Now you change the DAC output. Hundreds of milliseconds have passed with tens of amps running through your battery.
LATER EDIT after simulating both Tony's and Peter's solutions , they both share the same flaw, the transistor switch off/on voltage is over 4V shows the simulations. On a 3.3V Tony's solution doesn't cut the spike at all and Peter's solution is still pulling the DAC output. Which leaves the improved Swagministeren's solution the best that cuts DAC output to some mV on power on and switch off completely after putting enable to zero.
The simulation DC sweep shows large margins for release and cut for ENABLE over 2V the spike is less than 10 mV, for ENABLE under 500mV the DAC output is completely released.
Dorian
  • 2,546
    I really don't understand the down vote, the solution is simple, it does not require other I/O pins, it has hardware limit for the maximum current which makes-it software error proof. – Dorian Apr 04 '18 at 18:29
  • i already tried that. i already said that – Swagministeren Apr 04 '18 at 19:30
  • Sorry, I missed that, It was there from the beginning? The spike is still 2V with 12k? – Dorian Apr 04 '18 at 20:03
  • If we assume a DAC reference of 5V you are right that it would correspond to 50mV with a 1K resistor, but the reference for the DAC is 3.3V so i should get 33mV, should i not? If i put a 12K on its not enough to clamp the voltage. If i put in 1K it clamps the glitch to 50mV but it also pulls down the DAC once its configured so it will read out less than i tell it to in software. – Swagministeren Apr 05 '18 at 13:04
  • If i put in an RC circuit like you described it dampens the glitch on first power up, but the capacitor stays charged when i cut the power supply for the mbed. – Swagministeren Apr 05 '18 at 13:14
  • No , I was using internal pull-up value of 100k which has a big tolerance, don't stick to numbers, even with 3.3V is close enough. With divider that has 12K impedance overall the glitch will be divided to with the ratio (6:1 in my example) – Dorian Apr 05 '18 at 13:19
  • You cut the power only from the embed and not to the all circuit? Anyway , the current will go slowly down , nothing happens. See also solutions in software , why is the glitch so long. What happens from power on to DAC on? – Dorian Apr 05 '18 at 13:23
  • Let me point again if I understood well , if you miscalculate, some overflow occurs or anything goes wrong in software loading the DAC register with the maximum value the output will be 3.3V meaning 33A ? You use only small values for DAC register? – Dorian Apr 05 '18 at 13:40
  • For the divider needed: given x = maximum voltage that you expect to have on OA input ( 0.1 of max amps) , divider ratio = 3.3/x. Overall divider impedance to be in the acceptable range, not to high ( noise sensitive) Knowing max DAC register value >> max amps find DAC register value to output current ratio and use-it in your software. The glitch is already smaller now by the divider ratio. – Dorian Apr 05 '18 at 13:53
  • Then use whichever glitch solution you find more appropriate. I'm not quite sure that transistor solution will behave so well when you cut power only on embed. – Dorian Apr 05 '18 at 14:06
  • First of, thanks for answering me! I really appreciate it! I'm confused why you are talking of overflows, because this glitch happens at start BEFORE my code is being executed. It's when power is first applied the output goes bananas for a second or something like that. Or if i hold down the reset button it will stay in this undefined state. – Swagministeren Apr 05 '18 at 15:17
  • Im never gonna power of the mbed without powering down the rest of the circuit, cus they all draw power from the same source. In real life it will only be the startup glitch thats the problem. – Swagministeren Apr 05 '18 at 15:20
  • I have a fuse instead of where you put the current limiting resistor by the way – Swagministeren Apr 05 '18 at 15:21
  • A wise thing. I'm really sorry for mixing things but both cases power on glitch and software errors have some common ways to minimize the effects. One second? Why so long? Your solution with a transistor (without relay as I commented) seems to be pretty good to. Still , be cautious and use a divider or buy bag of fuses. – Dorian Apr 05 '18 at 15:32
  • The output is divided down im just not showing everything in that diagram. Just people keep commenting i should add a diagram. It's not even connected at the moment. For now it's just a resistor across the DAC. I'm not sure if it's exactly 1 second it was just a figure of speech :) I can measure it tommorow if it's of any interest – Swagministeren Apr 05 '18 at 15:38
  • A megaglitch then. I was thinking at tens of miliseconds at most. Then the capacitor is useless. – Dorian Apr 05 '18 at 16:45
  • over 200ms glitch. i attached scope captures :) – Swagministeren Apr 06 '18 at 06:48
  • Actually now it doesn't matter anymore as long as you can maintain this state indefinitely by pressing reset button, the capacitor can cut only a short glitch. Bad, bad, bad design for a microcontroller with analog capabilities to allow 2V on an analog output. – Dorian Apr 06 '18 at 08:39
  • I know. I just wanted to show you guys anyway. :) thanks for helping me out – Swagministeren Apr 06 '18 at 08:58
  • Thank you for sharing. We all have something to learn from this. – Dorian Apr 06 '18 at 11:49
