I am trying to make a sheet entry to use ports to connect devices in different sheets as explained in this image:
But I am getting an error from Altium saying:
Sheet Entry RB[0...7]
Warning: Nets whit multiple names
Error: Nets whit possible connection problems
Of course, nets are not being connected on the PCB. It is my sheet entry:
As you can see there is a red line below RB[0...7]. I want to connect a bus between the two sheets. If I put a simple pin instead of a bus I get the same error so I suppose the problem is in the sheet entry and not on the other sheets. My project looks like:
Thank you for your help :)
EDIT:
Esquema PIC.SchDoc:
Entrada Analizador Logico.SchDoc:
Settings:
PCB
I can't see any differences between your examples and my sheets
SOLUTION @Fake Name answer was ok, you have to name ports and net labels as RB[..] not RB[...] (2 points instead on three) and you have no put a Port in each bus AND a net label also whit the same name in order to connect them.
