I'm talking about a big difference between output current of the power supply and rated current of the device here. Would it burn up?
No the device will take up what it needs. – Parth Mar 24 '18 at 14:31
2If the grid can supply 10kA surges and you apply a 0.1A clock to AC outlet will it burn up? – Tony Stewart EE75 Mar 24 '18 at 14:40
unregulated power supplies don't reach specified voltage until specified current is drawn, so in that case you would have way too many volts. But, at 15A, it must be a regulated switching supply and you're fine. – dandavis Mar 24 '18 at 17:04
Think about it.
You have an electrical supply to your house. How many amps can it supply. My main fuse is rated at 63 A.
You have a light bulb. It's rated at 20 W. How many amps will it draw. Answer: \$ I = \frac {P}{V} \$ so that's about 0.1 A in 230 V land or 0.2 A in 110 V land.
Me too.
Would it burn up?
No. As in the case of the light bulb, the load will draw the current it requires and that's all.
You may want to consider limiting the current to a safe value in the event of a fault. Add a 2 A fuse in-line and you should be fine.
- 168,990
- 12
- 186
- 385
The power supply provides up to 15 amps. This does not mean that it has an output of 15 amps, always. The power supply will give the current requested by the device up to a maximum of 15 A.
- 486
- 5
- 19
Short answer: yes.
The 15 amp rating shows the maximum current which it will supply. It will also supply lower amounts of current just fine.
Think of it as a speed limit (although you shouldn't take the analogy too far). If your car can do 100 mph, that does not mean that it will always go that fast - only that it will if you need to. Likewise, a 15 amp rating only says that it will supply that amount of current if it needs to.
- 59,978
- 2
- 37
- 97
