I'm trying to find a 7-segment display BCD decoder IC with normal HEX display.
Most of the decoders that I managed to find have an output like this:
These hex values just look awful. I previously did this decoder on FPGA, and the output looked like this:
A b C d E F
Does anyone know some BCD decoder IC with "normal" HEX display?
Marko Gulin
  • 1,531
  • 32
    A binary-coded decimal decoder wouldn't do that - if it did it would be called a seven-segment hexadecimal decoder instead. And apparently they don't make those. – Andrew Morton Mar 21 '18 at 10:13
    Possible duplicate of [7 segment binary to hex](https://electronics.stackexchange.com/questions/351606/7-segment-binary-to-hex) – Andrew Morton Mar 21 '18 at 10:14
  • Look at this datasheet: http://www.ti.com/lit/ds/symlink/sn7447a.pdf – Marko Gulin Mar 21 '18 at 10:14
  • [This question](https://electronics.stackexchange.com/q/16034/41125) (not exactly a duplicate) and its answers mention the MC14495-P1 (seemingly difficult to get hold of, hence the question) and a Fairchild part DM9368 ([data sheet](https://media.digikey.com/pdf/Data%20Sheets/Fairchild%20PDFs/DM9368.pdf)) which I have no idea about the availability of. – TripeHound Mar 21 '18 at 11:14
    Used to use a TTL PROM or MOS EPROM for this. Today I would probably use a PIC with 11 or more i/o pins. – AlmostDone Mar 21 '18 at 12:08
  • I wasn't able to find any such IC, I will stick with the standard ones, and just won't use hex values. @AlmostDone Good suggestion using a PIC with 11 or more I/O pins! – Marko Gulin Mar 30 '18 at 08:37
  • I'm seeing the MC14495 chip available on Amazon now. – Patrick Chu Sep 16 '20 at 19:14
I have no idea on the availability of these chips:
  • V40511 (this one is an old DDR (eastern Germany) part, so definitely gone)
  • MC14495
  • DM9368
  • D345
  • D346
  • D348
  • CMOS 4311 or 4368
  • 74C915 ?
  • ICM7211 / ICM7212 (not the A variant)
The TIL311 is a complete hexadecimal display - might be an alternative.
Arsenal
  • 17,464
  • 32
  • 59
