I own a Roland JD-Xi synthesizer which is powered by an AC/DC adapter. The output voltage of the adapter is 5.7 V DC.
In an attempt to make things more mobile, some years back I made a cable that I could plugin into a 5 V power bank and my synth. It kind of worked but I got problems with some of the analog sounds on the unit, and most likely it is because of the missing volts, so to speak. I kind of ditched that project but now I have got to think about it again. One idea I have is to buy a 9 V power bank instead. I understand that some electronics support quite a wide range of volts.
So, I guess my question is: would it be unresonable to think that my synth actually could accept 9 V input although its power adapter outputs 5.7 V? If you think 9 V is too much/too high, could I make some little tweak to get it down a few volts?
If you are interested in the background, you can read about my project here:
http://muublog.blogspot.se/2016/01/making-jd-xi-mobile-by-replacing-ac.html
Thanks!
/Mathias
