I will need to connect several PCBs within a single enclosure for the project I am working on (They are split to reduce cost should there be a manufacturing error).
I need to connect an I2C Bus, 5V , an analogue and 3 digital signals (and importantly, the ground plane) from each 'slave' board to the master.
Is there a universal connector that would be appropriate for all of these signals? I am also under the impression that I want as 'wide' a connection for the ground planes as possible (Multiple connection points?) to reduce RF emissions?
to clarify: all of the digital signals are 5V logic, either from a PSOC, arduino or a CMOS chip. The analogue signal is 0-5V. Signal integrity of the analogue line is a priority as I cannot connect the external reference signal to the line due to pin restrictions and am relying on an internal reference.
The PCBs are 35mm Wide (Though I will take them down to an inch if I can manage), will be placed basically touching each other, and arranged like this:
. _____________________
|######MASTER#### |
| # S # |# S # | # S # |
| # L # |# L # | # L # |
| # A # |# A # | # A # |
| # V # |# V # | # V # |
| # E # |# E # | # E # |
|______|______|______|
Sorry for the bad ascii art, I made bad paint art but couldnt attach it.
