101
I did a big cleanup of my collection of parts today and I now have a big pile of parts on my desk (the majority of which is resistors). My previous method of finding the resistor value I wanted was to look through my little box and read the colour codes. Unfortunately I now have a lot of resistors, making an individual search almost impossible. Instead of reinventing the wheel, I put it to you my fellow chiphackers: do you know of any efficient (as in fast recall) ways to store and categorise components ?
I understand you can get lots of small drawers but it seems like such a waste of space to put only a single resistor of an unusual value in its own drawer.
jeremy
  • 5,055
  • 32
  • I got a kit of resistors so I wouldn't need to hunt through them anymore. Each value was in a little unlabeled bag, so I still had to hunt through them and read the color codes. >:( – endolith Jul 18 '10 at 14:57
    Don't overestimate the size of the storage cabinet required. Especially if you subdivide by depth, you can stock a lot of components. For example, if you're stocking 5% resistors, you only need 3 rows of 8 bins, divided into 5 categories (<100, < 1k, <10k, <100k, <1M) to stock every resistor from 1 ohm to 910k. – Kevin Vermeer Jul 18 '10 at 23:41
  • Plus colour codes are quick to read if you've stocked by magnitude. Say you want 47k, look at the 10k-100k box/bag for something with purple (7) and once you have a few, you can check if they're what you want. – XTL Jul 20 '10 at 15:00
    Oh man, if only I had an answer to this question... It's like the effort involved in keeping things organized is more expensive than the parts themselves. – endolith Oct 12 '10 at 01:18
    I think the question you need to ask yourself first is this: ** Is sorting the resistors worth your time**. Resistors are so dirt cheap that whenever I drop a few, or mix up my bins, I typically toss them, because I can replace all the lost resistors for ~$2.50, and it would take me more than an hour or two to sort them. Are you only worth $1.25 an hour? – Connor Wolf Feb 27 '11 at 04:12
  • If you spend an hour to save $9, you're working for less than minimum wage: http://xkcd.com/951/ – Kevin Vermeer Sep 20 '11 at 10:49
  • possible duplicate of [Organizing electronic parts?](http://electronics.stackexchange.com/questions/10513/organizing-electronic-parts) – Olin Lathrop Dec 27 '11 at 13:45
  • This type of question comes up periodically. Here is one previous example: http://electronics.stackexchange.com/questions/10513/organizing-electronic-parts – Olin Lathrop Dec 27 '11 at 13:46
    I cover one wall in double sided tape and just put them on there. Also good for storing flies, dust. – Rocketmagnet Apr 26 '12 at 16:02
29 Answers29
39
I keep resistors in drawers organized by the first digits of value.
R-1, R-12, R-15, R-18, R-22 and so on. (same for capacitors)
R-1 contains 100ohm, 1k, 10k... R-22 contains 22ohm, 220ohm, 2.2k, 22k...
Axeman
  • 3,498
  • If that still proved too much of a problem I suppose you could get some small plastic bags and subdivide each drawer further. – Amos Jul 18 '10 at 08:55
  • I think David L. Jones commended this storage method. – J. Polfer Oct 11 '10 at 17:29
    I bought a 1000-piece resistor kit that came with each value in a little bag with no labels. >:( I just spent a long time writing the value on each bag and sorting them by first digit. There are more 1s than 9s, though, so my meta-grouping ended up being 1.0-1.2, 1.3-1.9, 2_, 3_, 4_-5_, and 6_-9_. – endolith Mar 06 '11 at 00:42
  • The point is to sort resistors by the first two bands (the first two digits). So each value in the same drawer differs only by the third band (that is the "number of zeroes" after first two digits) and it's easy to discriminate between values. – Axeman Mar 09 '11 at 14:38
    I store resistors sorted by decimal magnitude: 0.1-1Ohm, 1-10Ohm, 10-100Ohm, 100-1K ... That way, if I can't find the desired value (i.e. I do not have it), I pick the next closest. – Vorac Oct 16 '12 at 07:44
    @endolith http://en.wikipedia.org/wiki/Benford's_law in action – Pete Kirkham May 08 '14 at 12:20
  • I also use this approach. Be prepared to split decade values R1 into multiple containers: there will be more of them than anything else. 100R, 1K, and 10K are commonly used (as predicted by Benford's law) and be best in their own container. – shimofuri Jul 18 '16 at 01:58
    @PeteKirkham Kind of a forced Benford's Law distribution - rather than coming about naturally, it's a direct result of the E12/E24 distributions of resistor values, with the intervals between them based on percentages, and the values increasing exponentially instead of linearly. Even in E24, you only get one value starting with 9 per decade. – WasabiFlux Oct 11 '18 at 20:41
    @PeteKirkham it's not Benford's Law if it's on purpose – user253751 Nov 02 '20 at 12:53
  • @user253751 I assumed that like shimofuri me, Axeman puts about the same number of resistors in their drawers and has larger numbers of resistors that are useful to their projects rather than having an equal number of every value available. I've got about ten times as many 10k as any other value as I bought them in bulk as I use them the most. – Pete Kirkham Nov 11 '20 at 12:30
30
I printed the E12 resistor series eight-to-an-A4 page, cut them up and purchased 100 ziplock bags (on eBay) to suit. The plywood box was a woodwork project! This upgrade replaced my previous similar system that lasted > 30 years.
Transistor
  • 168,990
  • 186
  • 385
26
I use a Raaco assorter:⁠⁠⁠⁠⁠⁠⁠
Raaco Assorter
n.st
  • 170
RedGrittyBrick
  • 14,602
  • 77
16
I don't do anything but prototype work and 5-10 run prototype assembly here so I don't keep that many parts around but here are my thoughts:
For SMD: This is about my favorite thing ever created I also have one of these for low volume stuff that comes on tape and is useful for testing, ferrite beads and such.
For ICs / connectors: I don't really reuse a lot of this stuff from design to design so they are normally just kept in their digikey/mouser bags and kept in the project box with the PCB's and connectors etc. I'm fairly good at keep a running inventory of what i have and what project it was for on my workstation so i can usually find this stuff quickly.
For Through Hole: I really don't use this stuff much. I have a fishing box style assortment of ceramic caps, one of 1% 1/4W resistors, one of aluminum caps, and one full of other stuff, diodes and transistors, etc. I don't really use this very often with the exception of a resistor or cap here and there if I need to blue wire something onto an early rev design. This could definitely be better organized.
JYelton
  • 32,302
  • 134
  • 249
Mark
  • 3,672
  • That SMD binder is awesome! I was just looking for something like that last week! I'll definitely be getting a few. Thank you! – pingswept Jul 18 '10 at 19:46
  • I also use the SMD binder from Aidetek with good results. – lyncas Jul 10 '12 at 21:22
    The second link is dead, could you describe it? – Zachary Vance Dec 11 '16 at 21:50
  • Wayback link for SMD box: https://web.archive.org/web/20190214212712/http://aidetek.com/mm5/merchant.mvc?Screen=PROD&Store_Code=A&Product_Code=BOX-ALL&Category_Code=Encl and – Craig Younkins Aug 04 '20 at 20:55
  • Even the Wayback link is dead now: "This snapshot cannot be displayed due to an internal error." – TheAmigo Feb 18 '22 at 02:30
    @TheAmigo - Hi, The problem with the Wayback link that you report, seems to have been temporary as it's working for me now. In case that link does fail again, on that archived webpage is [this YouTube video](https://www.youtube.com/watch?v=csvNRMqsRns) which shows that box for SMD components. || That supplier's current website shows a slightly different (I think?) version of the product, but using the same name "BOX ALL" [here](http://aidetek.com/mm5/merchant.mvc?Screen=PROD&Store_Code=A&Product_Code=BOXALL&Category_Code=Encl). Hope that helps. – SamGibson Feb 18 '22 at 04:21
  • Here's an updated product link: https://aidetek.com/mm5/merchant.mvc?Session_ID=94e988b001de7fb84d94bb9948d6baeb&Screen=PROD&Store_Code=A&Product_Code=BOXALL&Category_Code=Encl – tufelkinder Jun 22 '22 at 16:06
12
My favorite is this: Cubic Configurable Storage Toolboxes
You can view more pictures and videos here: http://www.dealextreme.com/p/cubic-configurable-storage-toolboxes-10-pack-4580
And there are more options like these:
Daniel Grillo
  • 7,659
  • 51
  • 69
  • First link broken – Brian Carlton Sep 19 '11 at 16:07
    Replacement for first link https://www.dx.com/p/rxdz-rectangle-smt-smd-electronic-components-storage-box-case-organizer-orange-18pcs-2019995 or better yet https://www.aliexpress.com/wholesale?SearchText=smd+components+storage+box – Mark Jeronimus Dec 07 '18 at 15:40
Last time I bought a resistor assortment from Farnell (61 values x 100 pieces each) I bought them with a cabinet with 60 drawers. The cabinet was virtually for free, compared to the cost for 6100 resistors.
For SMD I find Licefa V11-3 boxes extremely handy.
Each of the 60 phials (about 1cm x 1cm x 2.5cm) can contain tens of 0603 or SOT23 parts, and because you take the phial out of the box when you need a component they don't get mixed up. Very important for MLLC capacitors, since they don't have a marking.
Box exists in 60 or 130 phial versions.
My only issue is that the phials aren't anti-static.
stevenvh
  • 145,145
  • 455
  • 667
    Ow, painful: 60 drawers for 61 values! :-) – Federico Russo Jul 16 '11 at 11:02
    @Federico - yes, the 61 values are 10\$\Omega\$ to 1M\$\Omega\$ in E12, but 61 is prime, so not the ideal number for a cabinet :-( – stevenvh Jul 16 '11 at 11:10
  • I use those things since 15 years more or less for all tiny SMD components (0603, SOT23, even tiny chips like PIC16F1824 (QFN-20) fit in there... I would be happy if slightly larger would exist for QFN-28 or similar ;-) – Ale Mar 10 '21 at 14:02
We keep our through-hole resistors in small ziplock bags, and keep those bags in baseball card organizer pages (the plastic loose-leaf pages with nine pockets on each side). All of them fit in a three-ring binder. Whenever we need a particular value, we just page through the book. We also add a little card to each pocket with the value that belongs there, so we know what to restock when we're out.
The downside is that if you turn the book upside down you're going to make a huge mess, but amazingly enough, in the two years we've been using this system that hasn't happened once.
phooky
  • 1,008
    And on July 21, 2010 someone turned the book upside down... – Simurr Feb 05 '11 at 05:59
  • I also do this, without the ziplock bags. The card holders are tight enough, that I have never had a problem with them falling out. I do keep it on a shelf above my bench and am careful not to invert it, but I don't think it would be disastrous if I did. – captncraig Sep 19 '11 at 22:30
Coin envelopes. Size #1, 2.25" x 3.5" (although I used to be able to get smaller). Known to Amazon as "Coin and small part envelopes", because small parts is the other thing people (used to) keep in them.
You write the part number / value on the envelope, and just line them up in a box in order. Stores much more compactly than any small-plastic-box solution, is suitable for reasonably flat parts like resistors, small capacitors, cut-tape prototypes, flat-pack chips, and is easier to read and label than a plastic bag.
small part envelope approx 60mm x 90mm
david
  • 4,364
  • 30
I am a Physics teacher and came up with this idea for storing resistors that I use time and time again when doing practicals with resistance. I have also added other components so I don't have to go looking for them in little pots etc.
This works well for me as I don't have loads of components, but just enough for it to be a pain to not have a solution like this.
I also marked the holes with board pen so then can be reinserted in the right place easily
user41522
    I'd be very wary of something which involves a sliding action against expanded polystyrene in a static sensitive context. – Pete Kirkham May 08 '14 at 12:29
    Not a great place for MOSFETs... but resistors shouldn't suffer any ill effects from this (nor will they build up a charge). – MartyMacGyver Aug 13 '16 at 06:18
If you work with SMD resistors and capacitors kitboxes are the best.
For resistors: resistor kitbox
For capacitors: capacitor kitbox
You can find them on for example on ebay with the keywords: "smd resistor kit box" and "smd capacitor kit box"
kimliv
  • 628
I just love these Duratool boxes:
The horizontal dividers are removable, and the bottoms are curved so it's easy to pull out small components; they don't get stuck in corners.
They are cheap too! 10 boxes for £14 and I couldn't be happier. Messing around with the breadboard is now more fun than ever before:
They do have some of the most difficult to peel stickers right across the front though...
Roman Starkov
  • 2,731
  • 26
For through-hole parts I use something like this:
http://www.amazon.com/gp/product/B000CRHD6K/ref=oss_product
You can find a list of standard resistor values here: http://www.rfcafe.com/references/electrical/resistor-values.htm
Then just start making labels (color-coded labels in excel work great - put the color code on there for your reference). In fact I have the labels I made with color codes. I think if everything still works right after uploading to Google Docs that these should print out on mailing labels - maybe two or three to a label?
http://spreadsheets.google.com/ccc?key=0AlW3tzPu0DsLdHVtZHBmc1pKajdfSUtoSG8ySjI5dVE&hl=en&authkey=CMS268gM
AngryEE
  • 8,669
For TH and larger parts I use lots of small drawers. I also use the Akro-mils cabinets with dividers. http://www.amazon.com/gp/product/B00018AR5Y/192-5968131-0652527 These are nice because you can different draw sizes in a 17"x11"x11" cabinet. Very expensive unless you can find them surplus.
For SMD components I use a combination of stainless steel tins and watchmakers tins. I built some low-profile trays that hold the tins. See http://www.luciani.org/no-place-to-go/comp-storage/index.html
One very nice thing about the tins is they are small. For most designs you can kit up the different components on your bench.
Daniel Grillo
  • 7,659
  • 51
  • 69
jluciani
  • 11,646
I keep mine in small labeled envelopes (hand-written), with each decade in a labeled larger envelope, and keep them all in a cardboard box. I have every value from 1R0 to 10M0 (1% metal film) stored that way.
I ought to sort the small envelopes before putting them back in the large envelope, to save time finding a particular value, but I don't bother.
Leon Heller
  • 38,774
  • 60
  • 96
Here is an Instructable article on how to use ordinary book binders with zipper bag inserts. You can store smaller ziplock bags inside the larger zipper bags using one of the sorting schemes others have suggested here.
BTW, I would have just added this as a comment to phooky's answer, but I don't have rep on this site yet. Basically the same thing, but they won't fall out when turned upside down line the baseball card holders.
Daniel
  • 101
If really pressed for space, I think I'd lump everything 100 ohms and under in one bin, everything 1M and above in another, then one bin each for 100-1K, 1K-10K, 10k-100k and 100k-1M, but those things with all the little drawers are very cheap and easy to come by.
JustJeff
  • 19,163
  • 75
I use glassine envelopes and keep them organized with little tab dividers. They're cheap enough to have one for each value and expandable enough to hold all of my SMD and most of my through-hole components.
PeterJ
  • 17,131
  • 56
  • 91
Flyguy
  • 116
A classic resistor storage solution was made by one of the resistor manufacturers, can't remember which off hand. our shop her at work has a large rack of them 8 long bin slots per drawer, 4 drawers per cabinet , and yeah when we have ALL 10% values in both 1/4 and 1/2 watt, thats a few racks (grin), then add another two rows for some 1 and 2 W, but with fewer values among those. I think they were, may still be made by Ohmite. not sure where you find them and we could use a couple more. My recent restocking of those drawers found a few slots missing from the complete selection I ordered (grin). Will try to get 1) a photo of one, and 2) a source, just in case you really want one.. the bins WILL hold 200 of the 1/4 watt ( proven by test,smirk) less of anything larger ( like the 1/2s). I no more than wander away from here, than I find a pretty good picture of this box type on EBay.
While I am thinking about it, when I set up my home shop I had access to some rather perfect small flat tray boxes. two of them could hold a complete decade of the standard 10% values at about 10 per value. 14 of these convienently fit on a small area of the shop bench. recently I found a very large stock from a local 'silent key' ( radio ham that passed away ) THAT had a substancial section of resistors and came in a semi organized 60 drawer acro-mills cabinet, which has become my enhanced shop stock.
Also in passing velmann sells an adaquet starter kit of resistors about 70 values at 5 per.. and a cost around $10. among sellers is Gateway ELectronics ( local to me, but gatewayelex.com for those not in the midwest )
m.Alin
  • 10,638
  • 62
  • 89
chuck
I've been contemplating a system using labeled envelopes, but I haven't actually done it yet.
pingswept
  • 12,581
  • 64
I've put some of the passives in ziplock type freezer bags. They're transparent and you can write on them easily. Minigrip brand mini bags are about 10x10cm and I could file them in an old floppy disk organizer box. It's not quite ideal, though. Fresh resistors and diodes are kept in those "belts" as long as the glue holds and SMD's are in their tapes.
I found a source for surplus lot of those plastic boxes (also transparent) with lots of little compartments. I put a piece of tape on each with a number and have kept a small database that tells me what chips to find in which box and how many I have. Those boxes are nice in that they protect parts mechanically. They tend to be horribly expensive, though.
I also have some IC tubes and (Maxim's sweet sweet snappy) sample containers, ESD foam etc that I've gathered over the years that I can store stuff in.
And finally there's a few small drawer units from Ikea that I keep tools, batteries and solder/wick/flux/paste etc in.
I absolutely hate those "organizers" that shops use with the metal frame and hard plastic drawers that gather dirt, waste space, rattle and every now and then spray all the contents on the floor when you open a drawer quickly and the stop catches and it does that magic slip and flip.
There's probably no single container to end all containers.
XTL
  • 1,223
Personally I use the same thing I've used ever since I was a kid; a little "cabinet" full of plastic drawers. You see them at any hardware store for holding nails and screws and nuts and bolts. Cheap and works pretty well, although if the cabinet tips you're in for a bit of a job.
I organize them numerically; Starting with the smallest capacitors (1-50pf, 51-500pf, 501-999pf, etc.) in whatever "jump" works. e.g. I only seem to use 4.7pf, 22pf, 47pf and 100pf caps in that range, so they all go in one bin. I have 0402, 0805, 1206 and through-hole caps in the same drawer, unless the TH parts are big. It's really not that big a chore to pull out a drawer and look for the right package.
For "common" values (0.01uF, 0.1uF, 10uF, etc.) they each get a drawer all to themselves, usually with the through-hole variety in their own drawer. I find I buy 500 of the one kind of cap, and just the SMT size takes up most of the drawer.
I do the same with resistors and inductors.
For semiconductor devices, I have all the small-signal diodes in one drawer, all the zeners in another, all the rectifiers in another (again, with TH in their own drawer becuase they're big)... I have a drawer each for red, green, yellow and blue LEDs, and my NPN and PNP transitors get separate drawers too.
Solder and angel-hair wire (I actually use "bare" (bus) 30AWG wire and 26 or 28AWG nylon tubing) go on threaded rods which sit in a holder made out of angle-iron. THis lets the spools turn and keeps the spools out of the way.
I think I'll end up putting all the through-hole devices in a separate cabinet of drawers. ICs I tend to keep in a box, although the smaller and more common devices will end up in drawers as well.
Generally I keep the SMT components IN the plastic DigiKey or Mouser sleeves (the ones with the DigiKey labels on them.) Helps me with two problems: losing small parts and re-ordering. Also, if a drawer spills, it's easy to clean up, and it's impossible to mistakenly file the part in the wrong drawer. (I also take out one drawer at a time when I'm building boards, which helps avoid mixups.)
akohlsmith
  • 11,162
  • 35
  • 62
For passives (resistors/caps) I use little coin envelopes, one value per envelope, with the envelopes kept in a shoebox that's subdivided so they can stay upright and in order. I segregate by types, of course.
I previously used a hole punch to put a hole in each envelope, and then strung them on a keyring, but as the number of values increased, that got a bit unwieldy.
For ICs and the like, I have so few hanging around that I just keep them in little ESD bags in a box. With so few to look through it's not worth better organizing yet.
Michael Kohne
  • 2,711
I keep my low-power resistors in empty matchboxes glued side by side and labeled with the resistance range. For example, the first matchbox is for resistors below 100 Ohm; the second is for 100<=R<1k; the second is for 1k<=R<10k etc, and the last is for resistors equal to or above one Megaohm. A matchbox full of matches costs the same as two 0,25W 5% resistors here.
motoprogger
  • 1,301
Component and Parts Storage
This is a useful reference. (and links back to here)
Ricardo
  • 6,134
  • 52
  • 85
russ_hensel
  • 2,904
For small components I recommend these mini storage boxes. The resistors, diodes, LEDs are easily fit in it. The best advantage of this versus a divided box with one lid, that it opens invidually. It is very useful when you accidentally knock off the box from your table... alt text
csadam
  • 1,626
  • It looks something of a bother to have individual boxes in contrast to a divided box, but then that's a good point about spillage. I once had a cat run into the room and leap on the table, causing 100s of resistors to go flying all over. – DarenW Dec 04 '10 at 18:47
  • The original link to these drawers is broken. Here is the correct [link](http://dx.com/p/configurable-storage-toolboxes-3-pack-4727). Note that they are $2.43 for a set of three (plus S/H), which may be quite steep pricewise especially for resistor/capacitor storage. – Michael Goldshteyn Nov 02 '12 at 16:21
Joe Knows Electronics 1/4W 86 Value 860 Piece Resistor Kit
This product -- as simple as it is has really helped me to become more organized. It is a box that contains several plastic bags. Each bag is labeled with the resistance value. When I get a new resistor it goes in the index (I have a different index for each Watt rating). When I need a resistor I simply flip to the value that I need and quickly only check the color bands when precision is a concern.
The box includes 86 values from zero (seriously) to 10MΩ and is organized from lowest value to highes. It even has a handy color chart on the inside for quick reference. It comes pre-loaded with 10 1% precision resistors for each value (860) pieces.
Ricardo
  • 6,134
  • 52
  • 85
ThatGuy
I have reduced the range of resistors for prototypes to 1.0 1.5 2.2 3.3 4.7 6.8. This reduced the total number of boxes and meant buying larger numbers of the same resistor value. In NZ the difference between wholesale say a box of 1000 and retail say 1 to 10 was many times.
I have the decades on one axis (usually the Y axis_ and the cut down preferred values on the other (usually X axis) of the minidraw set. Due to supply inconsistencies in NZ the draw sets keep changing when I set these up for others. The key of matrixing the decades with the shortened preferred value range is to reduce the chance of selecting the wrong resister. Ability to read the colours doesn't improve with age. This worked OK for me and when SMD parts arrived in numbers I just put them in the same drawers. I know everyones work is different and the more digital the work is the fewer values you can get away with. Clearly if you are doing lots of Analog then you will want more values.
What some others do is have every conceivable resister value and stock very few caps. This is sensible because resisters are far cheaper than quality close tolerance caps.
Passerby
  • 72,580
  • 90
  • 202
Autistic
  • 14,235
  • 65
For smaller quantities, try putting them on a piece of Veroboard. I used to do this when I was a TV engineer. Easy to store and easy to read off the values. I also used a card index drawer which was just the right size for filing the bags of ten resistors that we got from RS.
Pete
Well, I use old sweet boxes which have sections like the 2 I'm using have 7x10 and 6x8 which are similar to many boxes shown here. With the only difference that there are free. Some similar chocolate boxes are also there.
Akshit
