I have one IR Thermal Sensor (mlx90614 with this datasheet)
based on datasheet communication with sensor is in this way:
Some of example is in the here: mlx90614 example arduino
The code for working with arduino Base is here:
#include <i2cmaster.h>
void setup(){
Serial.begin(9600);
Serial.println("Setup...");
i2c_init(); //Initialise the i2c bus
PORTC = (1 << PORTC4) | (1 << PORTC5);//enable pullups
void loop(){
int dev = 0x5A<<1;
int data_low = 0;
int data_high = 0;
int pec = 0;
i2c_start_wait(dev+I2C_WRITE);
i2c_write(0x07);
// read
i2c_rep_start(dev+I2C_READ);
data_low = i2c_readAck(); //Read 1 byte and then send ack
data_high = i2c_readAck(); //Read 1 byte and then send ack
pec = i2c_readNak();
i2c_stop();
//This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
double tempData = 0x0000; // zero out the data
int frac; // data past the decimal point
// This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
tempData = (double)(((data_high & 0x007F) << 8) + data_low);
tempData = (tempData * tempFactor)-0.01;
float celcius = tempData - 273.15;
float fahrenheit = (celcius*1.8) + 32;
Serial.print("Celcius: ");
Serial.println(celcius);
Serial.print("Fahrenheit: ");
Serial.println(fahrenheit);
delay(1000); // wait a second before printing again
SO i need to chnage this code for my mikrobasic programing the avr so i have changed those codes and made this code:
program mlx60914
symbol LCD_RS_my = PORTc7_bit
symbol LCD_EN_my =PORTc6_bit
symbol LCD_D4_my =PORTc2_bit
symbol LCD_D5_my=PORTc3_bit
symbol LCD_D6_my =PORTc4_bit
symbol LCD_D7_my=PORTc5_bit
symbol LCD_RS_Direction_my = DDc7_bit
symbol LCD_EN_Direction_my =DDc6_bit
symbol LCD_D4_Direction_my =DDc2_bit
symbol LCD_D5_Direction_my=DDc3_bit
symbol LCD_D6_Direction_my =DDc4_bit
symbol LCD_D7_Direction_my=DDc5_bit
dim celcius,fahrenheit as float
txt1 as string[6]
' Lcd module connections
dim LCD_RS as sbit at LCD_RS_my
dim LCD_EN as sbit at LCD_EN_my
dim LCD_D4 as sbit at LCD_D4_my
dim LCD_D5 as sbit at LCD_D5_my
dim LCD_D6 as sbit at LCD_D6_my
dim LCD_D7 as sbit at LCD_D7_my
dim LCD_RS_Direction as sbit at LCD_RS_Direction_my
dim LCD_EN_Direction as sbit at LCD_EN_Direction_my
dim LCD_D4_Direction as sbit at LCD_D4_Direction_my
dim LCD_D5_Direction as sbit at LCD_D5_Direction_my
dim LCD_D6_Direction as sbit at LCD_D6_Direction_my
dim LCD_D7_Direction as sbit at LCD_D7_Direction_my
dim Soft_I2C_Scl_Output as sbit at PORTC0_bit
Soft_I2C_Sda_Output as sbit at PORTC1_bit
Soft_I2C_Scl_Input as sbit at PINC0_bit
Soft_I2C_Sda_Input as sbit at PINC1_bit
Soft_I2C_Scl_Direction as sbit at DDC0_bit
Soft_I2C_Sda_Direction as sbit at DDC1_bit
sub procedure Work_MLX90614()''dim celcius as ^double, dim fahrenheit as ^double)
dim dev1,data_low1,data_high1, pec1,frac as integer
dim tempFactor,tempData as double
'dim celcius,fahrenheit as float
dev1 = 0x5A<<1
data_low1 = 0
data_high1 = 0
pec1 = 0
'' Write
Soft_I2C_Start() ' issue start signal
Soft_I2C_Write(dev1) ' address dev
Soft_I2C_Write(0x07) ' write 01 to year word (REG6)
' Soft_I2C_Stop() ' issue stop signal
'' Read
' Soft_I2C_Start() ' issue start signal
' Soft_I2C_Write(dev1) ' address dev
data_low1=Soft_I2C_Read(1)
data_high1=Soft_I2C_Read(1)
pec1=Soft_I2C_Read(0)
Soft_I2C_Stop() ' Issue stop signal
tempFactor= 0.02 '' 0.02 degrees per LSB (measurement resolution of the MLX90614)
tempData = 0x0000'' zero out the data
' tempData=data_high and 0x007F
tempData = ((data_high1 and 0x007F) << 8) + data_low1
Lcd_Cmd(_LCD_CLEAR) FloatToStr(celcius,txt1) lcd_out(1,1,"Celcius: ") lcd_out(2,1,txt1)
end sub
main:
celcius=0
Soft_I2C_Init()
Lcd_Init()
Lcd_Cmd(_LCD_CLEAR) ' Clear display
Lcd_Cmd(_LCD_CURSOR_OFF) ' Cursor off
while 1
'lcd_out(1,1,"Celcius: ") FloatToStr(celcius,txt1) lcd_out(2,1,txt1)
Work_MLX90614() '' FloatToStr(celcius,txt1) lcd_out(1,1,"Celcius: ") lcd_out(2,1,txt1)
delay_ms(300)
wend
end.
So it don't Show, but the LCD don't show the correct number, it's show -273.00 or 378.00 or 59.00 number or ... so it's don's Show correct temperature only some times show near correct temperature degree !!!
Dose these number's Showing the I2C communication is done correctly or this is one signal of mismatching in I2C configuration?
It must be recommended that the IR sensor communication (SPI Connection) don't Show sometimes the correct number with Arduino don't Show correct too.
my guess is the conversion from Arduino code to Mikrobasic from this codes are too important and may be have some mistake in my conversion.
// read
So the code's and simulation in Proteus (without mlx90614 library) is here: simulation in Proteus Thanks a lot .
