I have a microbit setup with a relay controlled by pin 0. The relay is being used to turn on a simple motor. Everything works fine when the motor is connected to a separate 3v power source, but if I try use the gnd and 3v outputs of the microbit to power the motor the microbit immediately resets once the relay switches on.
These are my connections to the relay: Microbit 3v > relay DC+ Microbit gnd > relay DC- Microbit p0 > relay IN
This fails: Microbit 3v > relay NC > relay com > motor > microbit gnd
This works: 3v battery + > relay NC > relay com > motor > 3v battery -
I have tried adding a resistor in the path, but the smallest I have is 170 ohm which is too much to power the motor.
Brian Flynn
  • 103
    Don't use a series resistor. Use a circuit like this: https://electronics.stackexchange.com/questions/95140/purpose-of-the-diode-and-capacitor-in-this-motor-circuit -- or if you want to be able to drive the motor forwards and backwards, use an H-bridge: https://electronics.stackexchange.com/questions/80137/how-diodes-protect-h-bridge-dc-motor-driver – MarkU Feb 18 '18 at 07:54
  • Sounds like you need to add some decoupling. –  Feb 18 '18 at 11:32
  • @briandrummond - do you mean using a capacitor to separate the power from the ?https://en.m.wikipedia.org/wiki/Decoupling_capacitor ? Or something else? – Brian Flynn Feb 19 '18 at 16:56
Sounds like you might be trying to draw too much current through the Micro:bit itself (through its 3V Pin). You could try using the same powersource wired to both Micro:Bit AND the motor (in parallel) - with the relay on the positive motor wire.
Evan
