I hope this is an easy question for you.
I am using a plastic box as a watertight enclosure for a single board computer and some accessories. I will be using an AC power source coming in through a 3 wire wet pluggable bulkhead connector. It is then converted to DC in the box to power the components (like the SBC, a serial-to-usb converter, etc). The AC/DC converter (Mean well brand) has a place for attaching a ground.
My question is: will using the ground screw on the AC/DC converter be enough to ensure this box is safely grounded? My gut says yes, especially since the box is plastic, but I am going to be using this in a saltwater environment. I really don't want to kill myself so I'd like to be extra sure before I deploy this baby.
Thanks much!
EDIT: Unless the ship goes down, this box will not be submerged. It will only be exposed to saltwater spray during cleanup.
imno1
    No, AC power going into a plastic box in a saltwater environment is not necessarily safe. For example, a single point of failure in the seal, which can degrade over time can result in a hazardous condition. Just grounding the ground screw on the AC/DC supply is not going to prevent a hazard. – John D Feb 06 '18 at 23:13
  • and how will you remove the heat thru plastic ? – Tony Stewart EE75 Feb 06 '18 at 23:38
  • Thanks John D. Can you clarify what you mean by 'hazard'? I know there is the potential for water intrusion, broken wires, sentient computer boards, etc. Par for the course when dealing with electronics on a ship. I guess a better question is: will the box be safe to touch until it can be removed from AC power if one of those potentials happens to occur? Is using the grounding screw and a plastic case enough? If not, what else should I do? - Thanks – imno1 Feb 06 '18 at 23:44
  • What difference do you imagine that the ground screw does to a plastic enclosure? – MrGerber Feb 06 '18 at 23:56
  • I would think the saltwater should disperse and absorb any RF as well as a Faraday Cage. But where are you when this is in saltwater? in a sub? – Tony Stewart EE75 Feb 07 '18 at 00:03
  • Going on a ship, I would check to see what regulations apply to that particular vessel: ABS, DNV, etc., and then design the equipment to conform to that. Will your equipment be in a hazardous location, such as where explosive gas might be present? If so, then another set of requirements apply. – AlmostDone Feb 07 '18 at 00:06
    It's not uncommon for equipment enclosures made of glass reinforced plastic (GRP) to be used in exposed areas of a ship or offshore vessel. IP56 is usually the minimum IP level allowed in wet areas. Inside the enclosure, you can use a brass plate as a backup surface for metal bulkhead connectors; it provides a PE connection point inside the enclosure. Any exposed metal surfaces must be bonded to the common PE point, which must have a path back to an earthing point on the vessel. Again, check your ship's classification for the standards you need to adhere to! – AlmostDone Feb 07 '18 at 00:15
    Hazard means the potential for injury. In this case saltwater is a fairly good conductor so a leak that allows a salt water bridge between a live conductor and the outside of the enclosure could cause electric shock. @AlmostDone is correct, you have to follow the applicable standards, and after following the standards I would add a GFI for an added layer of safety. – John D Feb 07 '18 at 00:38
  • Edited my post to clarify this will not be submerged. Thanks AlmostDone. This box will be at least at IP66 when completed. I have a meeting with the ship personnel next week and will ask about their requirements. One more question if I may: If I use a plate, will connecting back to the AC ground be enough to get it back to the ships earthing point? – imno1 Feb 07 '18 at 00:43
  • @imno1, you best ask the ship personnel that question. Knowing nothing more than what's been exchanged in this forum, anything I tell you would just be my opinion. If you want to do some homework though before you have your meeting, you can look at some vendors or GRP enclosures and see what is available by way of grounding plates. R. Stahl and Abtech are two I have used in the past. I'm sure there are plenty others. – AlmostDone Feb 07 '18 at 00:54
  • In the USA your 'product' would have to be in a NEMA 4X fiberglass water-tight enclosure, including forced water and submersion. You can do no better than that. A PVC enclosure may not have a 4X rating. The rating label would be inside the enclosure. –  Feb 07 '18 at 01:21
  • Thank you all for your comments. This has been very helpful and will aid me in my discussions with the ship. – imno1 Feb 07 '18 at 18:08
If the screw is exposed out of the plastic box, it is an accessible conductor. If it is screwed with the Mean well AC-DC converter, the easy way I think is to make sure the converter meet safety standard. For example to check whether it has EN61204 safety standard certificate. If so then you are sure the converter grounding is okay. Next is you have to make sure the screw contact well with the grounding. However, if you can loose the screw without opening the plastis box, you cannot just ground the screw. I would keep the screw inside the plastic box and do not let any metal exposed out of the box.
However, to make the box safe, grounding or not is not the only factor to consider. As you said you are using a plastic box, if there is not accessible conductor (aka exposed metel), you do not need grounding, just like the hair dryer in bathroom. Another important safety factor is the creepage and clearance between you electronics and the accessible surface (the plastic box surface). It depends on the working voltage level, rated impulse voltage level etc. For example, with reference to EN60335, the clearance for a common 230V appliance is 3mm. However as your product will be exposed in a salty environment, I will use the next higher level which is 6mm. The thickness of the plastic better be more than 1.2mm. And even better is you have double insulation, that means you have two plastic box with total clearance of 6mm.
eepty
  • 279
  • Thank you, eepty. This is very useful information. The screw is inside of the box, on the converter itself (looking into the EN standard now). As for clearance between the electronics and the box, it's on the order of inches, not mm. There will be plenty of room on the top and all sides. As for the bottom, I am planning on have a plastic board setting off of the bottom of the box a little over an inch to mount everything to. The box itself if about 7-8mm thick. – imno1 Feb 07 '18 at 18:05
I have a large Koi pond with underwater pumps driven by regular AC and I don't want dead fish but, luckily, legislation in the UK means that I must fit a residual current device (GCFI or ground fault current interrupter in the US) to outgoing AC connections for my pond.
This means that if water gets where it isn't intended (such as the live wire) and a potentially excessive ground current is caused, the interrupter trips the whole AC supply rendering it safe.
  • Thanks Andy aka. I am 92% sure the entire ship operates with GCFIs, but I will take that question to them when I go next week. – imno1 Feb 07 '18 at 18:07
