For the purpose of measuring particulate matter (PM) in air, I am trying to set up a DAC system for the PM sensor Shinyei PPD42NJ (info here and datasheet here).
I've been trying to just use a low pass filter to get an analog voltage, but I'm not sure how to calculate the appropriate capacitance and resistance. Concern: if I use the low pass filter, will past measurements affect the current measurements (unless the capacitor can be reset every time the voltage is sampled)? How often would I sample the voltage if the frequency of the LOW pulses are sometimes as low as .5 Hz?
The parameters of the PWM are Negative Logic, Digital output,Hi : over 4.0V(Rev.2) Lo : under 0.7V. Here is a picture with Channel 1 showing the usual behavior of the signal versus time.
Ricardo
  • 6,134
  • 52
  • 85
  • see also [this answer](http://electronics.stackexchange.com/a/34845/2064) – stevenvh Jul 11 '12 at 07:35
  • I wonder if Benjamin really wants an Analog output or not. If he does, the best filter is a switched integrator using the method I outlined. The voltage increases and never sags until the result is read and reset to 0. A sagging RC filter is like a leaky bucket counting rainfall. ( just a metaphor ) If you need a schematic for a simple switched integrate & dump, just ask. Someone can find, or pls indicate you prefer the PIC solution. – Tony Stewart EE75 Jul 11 '12 at 20:28
  • @Benjamin Weia << I wonder if Benjamin is still thinking about this question? – Tony Stewart EE75 Jul 18 '12 at 23:53
  • You want to sample at least twice the highest frequency of the signal to prevent aliasing: See [Nyquist-Shannon Theorem](http://en.wikipedia.org/wiki/Nyquist%E2%80%93Shannon_sampling_theorem). – sherrellbc Jun 27 '14 at 13:23
Although one could use a simple RC filter, I think one would do better to use some sort of digital filtering. The time scales you're looking at look well within the range of what a processor could handle. I would suggest that your best bet is probably to do something like sample the input pin once per millisecond and keep track of how many times the input has been low during each somewhat longer time interval (maybe one second or five seconds), and then use a digital FIR filter to add up those readings. A simple way to perform the filter FIR filter is to scale up each reading so as to be a bit short of the full range of a 16- or 32-bit integer, and then do something like (pseudo-code):
temp = new_reading
for each item in an array
  new_temp = (temp + array_item)/2
  array_item = temp
  temp = new_temp
loop
The final value of new_temp will represent a low-pass filtered value of the input; one can vary the number of seconds per reading and the length of the array to adjust the filter characteristics. Note that if one uses e.g. a sampling interval of two seconds and an array that's 16 elements long, only the last 32 seconds of input will be considered in producing the output (meaning that the output will fully respond to any change in input conditions within 32 seconds) but relatively "stable" input conditions will yield a relatively stable output (much more stable than with an RC filter that converges reasonably fast).
supercat
  • 45,939
  • 84
  • 143
To know what value of capacitor and resistor you want, you will need to think about the response speed you need to achieve. Looking at the waveform, it looks like you get a pulse every few seconds, and the pulses last tens of milliseconds. This is pretty slow, so:
  • The analog signal will be much slower than your pulse rate. You should expect the analog signal to take about a minute to settle when the pulse rate changes.
  • You will need to choose pretty large values of resistor and capacitor. The time constant of an RC filter in seconds is the product of the resistance in Ohms and the capacitance in Farads.
Since you're looking for something in the order of a minute, I'd start with 12k ohms, and 4700uF. See how that works. If you need a slower response, then use a larger resistor.
Here's what it looks like with 12k and 4700uF:
PWM RC filter
There are 0.1s pulses every 2 seconds over the course of 2 minutes. As you can see, it hasn't really settled, even after two minutes, and the variation in the analog signal is still about 5%.
With a smaller resistor, you can have faster settling time, but more variation.
With a larger resistor, you can have slower settling time, but less variation.
I don't know if this is an option, but have you considered using a microcontroller to read these signals? What will be reading the analog voltage? If it was going to be an ADC and a microcontroller, I would forget about the ADC, and just let the MCU take care of it. These pulses are so slow that even a computer made out of cog wheels could reliably sample them.
Rocketmagnet
  • 26,933
  • 92
  • 177
If pulses count, but amplitude and duration don't, then you can trigger a monostable multivibrator with them. Then you can change to measuring time which is reasonably easy to accomplish with a counter (in a microcontroller) in contrast to measuring very short spikes through a low pass filter.
jippie
  • 33,033
  • 93
  • 160
Looking at the data sheet, the "unit time" is 30 seconds.
I'm not sure why, without further details, you want to convert this to an analog signal only to then sample it again.
However, if you're committed to converting this to an analog signal, you'll need a filter with a very long time constant of the order of the "unit time".
Another option would be to integrate the signal with an op-amp integrator circuit that is sampled and reset every 30 seconds. This sounds like what you have in mind when you ask about memory of previous "measurements".
If you'll provide some more context, I can be more specific with my answer.
By the way, have you looked at this? The author interfaces this sensor to an Arduino.
Alfred Centauri
  • 26,502
  • 63
