First question
Whether we declare the array as scalar or vector, we can access each element bit by bit. For example, we can declare two arrays below.
reg scalar_array[0:9];
reg [0:9] vector_array;
always @*
begin
  scalar_array[0] = 1'b1;
  vector_array[0] = 1'b1;
end
I would like to know if the difference exists between two declarations.
Second question
Also, when I declare the two-dimensional array like below, I could access the entire row using the indexing operator[] for the variable declared using a below syntax.
reg[X:X] var_name [Y:Y];
However, I couldn't access the entire row when I declare the array using the below syntax.
reg var_name [X:X][Y:Y];
I would like to know how this concept can be synthesized on the hardware, and if they are both synthesizable, what is the difference between them.
reg [0:9] vector_array_2d [0:15];
reg scalar_array_2d[0:9][0:15];
always @*
begin
  vector_array_2d[0] = 'd1;
  scalar_array_2d[0] = 'd1; //raise the error!!
end
Paebbels
  • 3,897
  • 43
ruach
  • 349
For your first question, search for the difference between packed and unpacked arrays.
Your second question is a Verilog limitation with unpacked arrays - it only allows access to one array element at a time. SystemVerilog does not have this restriction. You can access an unpacked array as a whole, or select an entire dimension.
dave_59
  • 7,557
  • 26
  • Thanks for an answer. However, it seems that Verilog doesn't support multiple packed dimensions. Vivado raise the error when I tried to declare the packed array like reg[3:0][4:0] packed_array; – ruach Feb 05 '18 at 05:23
  • Make sure you have turned on SystemVerilog, use a *.sv file extension. – dave_59 Feb 05 '18 at 05:25
  • this answer is specific to SystemVerilog, not Verilog – Aaron Thomas Aug 12 '20 at 16:19
  • ref https://stackoverflow.com/a/24344363/2658159 – Aaron Thomas Aug 12 '20 at 16:26
  • @AaronThomas SystemVerilog introduced the terminology "packed"and "unpacked", the functionality was the same as in Verilog. Although Verilog only allows a single packed dimension. – dave_59 Aug 12 '20 at 16:28
  • thank you for the clarification. would it be correct to say that for Verilog, a vector is a one-dimensional packed array? or is vector a different concept altogether? – Aaron Thomas Aug 12 '20 at 16:30
  • In the Verilog, a vector is a one-dimensional packed array. In SystemVerilog, a vector is any packed array or packed struct. Integral/vector/packed are different words for the same concept. – dave_59 Aug 12 '20 at 16:34
For the first question, the difference lies in how the register is to be treated - as either a bus (a single value, wider than one bit) or an array (multiple values, stored under one name). It seems a little bit philosophic, but this answer provides more detail.
For the second question, it may rely on the manufacturer or provider. For example, Xilinx Vivado will synthesize multi-dimensional arrays of up to two dimensions only (ref UG901).
Aaron Thomas
  • 101
