The ETSI standard ETSI TS 102 221 describes the procedure for switching (and thus finding the appropriate) supply voltage in section 6.2:
6.2 Supply voltage switching
The terminal shall initially activate the UICC with the lowest voltage
class available. If no ATR is received, the UICC shall be deactivated
and activated with the next higher class, if supported by the
terminal. If an ATR is received at the first applied voltage class,
the contents of the ATR shall be analysed by the terminal. If the
operating class used by the terminal is not supported by the UICC, the
terminal shall deactivate the UICC and activate it with a supply
voltage class indicated by the UICC. If the ATR is corrupted, the
terminal shall perform the procedure at least 3 times using the same
operating class before rejecting the UICC. In case of 3 consecutive
corrupted ATRs, the terminal may activate the UICC with the next
higher class. The terminal is restricted not to use but the next
higher class in the retrial attempt in this case.
