I am designing a shift register. It has a control signal called RD which is asynchronous (so I can't use it inside the procedural block). The whole point is my n-1 bit shift register is value of the input if RD==1 or else it has high impedance; I am not sure how to write the assign the high impedance value because my n bit is a parameter so I can't define the number of bits.
inout [n-1:0] Data;
input RD;
reg [n-1:0] register;  //my register
Example: Data = (RD==1'b1)? [n-1:0] register: 'z ;
It's giving me an error. How can I define that if RD is 1, then I need to see what is there inside the register, and if it's 0 then, it should be high impedance?
toolic
  • 5,637
Dig_Verif_bee
  • 43
Unless you are using SystemVerilog, you cant declare a constant like that.
Instead use the replication operator. {(WIDTH){1'bz}} is a WIDTH bit wise constant of all z's. Just replace the width with however wide you need (can be a parameter).
Furthermore, it should be register[n-1:0] not [n-1:0]register.
The following should work:
assign Data = (RD == 1'b1) ? register : {(n){1'bz}};
Tom Carpenter
  • 63,168
  • 139
  • 196
  • can I not just write assign Data = RD == 1? register:{(n-1){1'bz}}; ??? – Dig_Verif_bee Jan 30 '18 at 16:18
  • No. And you keep asking us "I can't do " whilst the compiler already told you that you can't. Your bit select operator = []. The {} are concatenation operators. – Oldfart Jan 30 '18 at 16:25
  • @Digital_Treasure mostly correct. You would need to do `{(n){1'bz}}` as your number is n-bits wide. Also, I would keep the `(RD==1'b1)` in brackets for better readability and less chance of the compiler misinterpreting. – Tom Carpenter Jan 30 '18 at 16:57
    Just to clarify `'z` is a SystemVerilog constant construct that automatically sizes itself to width required by the context of the expression where it is located. – dave_59 Jan 30 '18 at 18:23
Thank you for the suggestions and guidance. I was able to code in the right pattern and get the expected results.
module shifter #(parameter Length = 1) (
  input clk,
  input rst,
  input EN,
  input WR,
  input RD,
  input SI,
  output reg SO,
  inout [Length-1:0] Data
  reg [Length-1:0] register;
  always@(posedge clk or posedge rst)
  begin
    if(rst == 1'b1)
       begin
        register <= 0;
       end
    else
     begin
         if(WR == 1'b1 && EN == 1'b0)
        begin
          register <= Data;
        end
     else if(WR == 1'b0 && EN == 1'b1)
             begin
         register <= {SI, register[Length-1:1]};
             SO <= register [0];
         end
      else if(WR == 1'b1 && EN == 1'b1)
           begin
           $display ("Illegal state");
           end
     else
         begin
         register <= register;
         end
      end
       end
   assign Data = (RD == 1'b1) ? register [Length-1:0] : {(Length){1'bz}};
   endmodule
toolic
  • 5,637
Dig_Verif_bee
  • 43
