I have the following code in my microcontroler program:
// Wait for ADC conversion to complete
while ( ( ADCSRA && _BS( ADSC ) ) == _BS( ADSC ) ) {}
Where ADCSRA is a register that will change its value once an analog conversion is completed and where I want to wait for a bit to be clear. This bit indicates conversion completed.
Looking at the resulting assembly code, the whole loop is replace by a single instruction:
in r24, 0x06 ; ADCSRA
The register is read, but its value isn't even tested!?
How do I have to change my C++ code to instruct the compiler to keep rechecking the register, without unnecessary delaying the program?
I use the avr-gcc toolchain.
EDIT: I changed the code as follows (Thnx: lhballoti):
while ( ( ADCSRA & _BS( ADSC ) ) == _BS( ADSC ) ) {}
Which changed the assembly code to:
38: 36 99 sbic 0x06, 6 ; 6
3a: fe cf rjmp .-4 ; 0x38 <__CCP__+0x4>
Which apperently solves the problem.
Check this page for the complete program and its disassembled resulting code.
