The FCCID website is great to see what frequencies are used by different systems. The FCC is of course limited to the US/North America. Is there a similar site for Europe or other regions?
FCCID pulls from... the FCC. Which does not have an equivalent in Europe. Canada has the IC. – Passerby Jan 26 '18 at 04:14
There is not a similar site for Europe, because the US and EC does not handle EMC the same way. You can read more about the difference in The accepted answer to this question.
TL;DR, there is no central register for Electromagnetic compatible products/manufacturers.
But, you state that you use the database as a resource to figure out what frequencies are used by what systems - then there is a register for that, of course. There are organizations that govern the use of frequency bands. Then it will be CEPT (The European Conference of Postal and Telecommunications) you want.
Specifically, The European table of frequency allocations and applicatons in the frequency range 8.3 kHz to 3000 GHz (ECA TABLE)
Bear in mind that all bands are not necessarily harmonized in all countries. To be able to know what frequency bands are being used for what systems in what country, you will have to refer to the local Postal and Telecommunication agency in each separate country.
- 851
- 8
- 17
1Except radio frequency use is (unfortunately) not harmonized across Europe. Some frequency bands are harmonized, others are not. You may have to check with national authorities in each and every country. – Lundin Jan 26 '18 at 09:33
