I see the question has been asked a few times about using rectifiers in parallel to get a higher current rating and this is not advisable however I wanted to ask how this would apply to a active mosfet regulator and rectifier namely the fh020aa commonly found in bikes having a peak current of 50 Amps.
My application will generate 120 amps peak and at 12 volts and a standard 3 phases rectifier would lose a lot of that power so I wish to use two of these in parallel with a brushless motor to gain 100 amps peak.
Can it be done? Or is there a more suited rectifier capable of taking the current?
