Lots of good answers. Most of which point toward the answer having no practical use outside an academic test. Pure silver is expensive and much softer than common copper wiring. Without reference I believe it introduces the same bi-metal issues as mixing aluminum and copper wiring. Thus silver is undesirable from engineering and theft standpoints.
Some of those engineering points become even more complex as you attempt to alleviate them. As was mentioned both alloying and working silver cause phase and density changes in silver plus the other included metals.
In reality standard amperage carrying capacity of copper and other wire in industry is based on a number assumptions: standard alloy, insulating materail, ambient temperature and humidity, minimum air space and circulation, safety margins. The most common of these standards are building codes for interior wiring where wire temperatures must not melt the insulation nor ignite paper or wood. I cannot remember if the US safety margin was 30% or 50% -- but I do remember that it was quite generous to allow for startup surge currents of electric motors and such.
A slightly different capacity standard is sometimes used in enclosed electronics. There ignition temperatures of paper/wood is replaced by softening/melting temperatures of wire itself...although the melting point of wire insulating material usually remains the governing factor except inside vacuum tubes.
So for that all important academic test or EXOTIC electronics application...I would say the question is missing a plethora of qualifying environmental criteria (ambient operating environment: temperature range and anything connected to cooling: such as surrounding gas/liquid composition and flow volume, other thermal sources, thicknesses of surrounding thermal conducting media {like part of heat sink}, etc etc)
Ultimately only a very few remote exotic environments (mostly space or deep sea) or microchips would justify even momentary consideration of silver as an alternative to just using a more over-engineered version of the standard copper circuits. Last I heard even micro-chips were considering copper more and more for chip to substrate connections as a replacement for gold assuming that corrosion issues could be overcome. And at those fine diameters I don't think silver has much advantage over copper as the protective tarnish becomes relatively thick to the application and plays hell with resistance calculations.
