17
Charging too quickly can cause the battery to blow up due to heat.
But what if I cool the battery down? Can I charge as fast as I want, provided that I cool it down sufficiently?
Can I enforce higher charging speeds by increasing the input voltage, if the battety is colder?
smci
  • 119
neverMind9
  • 742
    no ... chemical reactions have finite response time. – jsotola Jan 17 '18 at 08:28
  • Welcome to the site. Please quickly realise that this is not a free design house, homework-answering service or an on-line technical encyclopedia, copied out to you on demand. People will help you take the next step if your question shows that you've done as much as you possibly could on your own - which your post doesn't, I'm afraid. Please revise your question showing your work and findings so far, in considerable detail. Or delete the question if Internet searches give you your answer anyway. Again, a warm welcome to the site. – TonyM Jan 17 '18 at 08:31
    Re your edit - if you read the answers already given - what do you think??? – Solar Mike Jan 17 '18 at 09:48
  • Still helpful. Thank you for your answer,@Solar Mike. – neverMind9 Jan 17 '18 at 10:41
  • "Charging too speedy can cause the battery to blow up due to heat." -- also worth noting is that charging batteries causes degradation that limits the number of times they can be charged, and that this degradation happens more quickly at higher temperatures. Fast charging therefore reduces battery lifespan; cooling can help mitigate this. – Jules Jan 17 '18 at 14:02
    What sort of battery? Lithium and lead-acid (for example) may attract different answers. – Chris H Jan 17 '18 at 14:25
  • The real question is: Is the speed of chemical reactions slowing down when temperatures are dropping? I tend to say "yes". – Vladislavs Dovgalecs Jan 17 '18 at 23:27
Can I charge as fast as I want, provided that I cool down sufficiently?
No. To charge faster you need higher voltage to overcome internal resistance. If the voltage is too high it may cause damage due to electrolysis or other effects, depending on the battery chemistry.
A lead-acid battery will 'gas' when the voltage reaches ~2.45V per cell, as the water breaks down into hydrogen and oxygen. This causes a 'wet' lead-acid battery to lose electrolyte, and the gas mixture is an explosion risk. Sealed lead-acid batteries can absorb and recombine a certain amount of gas, but if the pressure gets too high they will vent. Having to keep below gassing voltage is the main factor that limits how fast you can charge a lead-acid battery, even at low current which doesn't heat the battery up much. If you ignore the gassing and try to charge even faster then charging efficiency could drop dramatically, due to gas bubbles reducing the effective electrolyte density and plate surface area.
High voltage can also cause increased corrosion, insulation breakdown, arcing between terminals etc. So you can't just increase the voltage 'as much as you want' to get a faster charge rate, even if you could somehow manage to keep all internal parts of the battery cool.
However with some battery chemistries you can increase charge current well beyond the nominal rate, at least for part of the charge cycle.
The chemical reaction when charging a Nicad battery is endothermic, so the battery naturally cools itself down while charging. If it has thick plates and interconnects to keep Ohmic losses low, a Nicad battery can be charged at very high current until just before full charge. However the current must be switched off as soon as it reaches full charge, else it will rapidly heat and build up internal pressure which may cause it to vent and/or short out.
High power Lithium-ion batteries can also be charged very rapidly during the 'constant current' phase. Li-ion batteries have very high charging efficiency, so they don't normally get hot during charging. The main limiting factor is the increased possibility of the (very thin) separator shorting out at higher voltage. Some high power Lipos are rated for up to 15C charge rate - flat to full in 4 minutes! However since maximum voltage is strictly limited, current must be reduced for the last 20% so the time to reach 100% charge is much longer.
Bruce Abbott
  • 55,540
  • 47
  • 89
22
You certainly cannot charge as fast as you want, but you can indeed increase the charging rate if you keep cooling the battery in the process. Though the point is not to make the battery colder than normal, rather, you want to prevent it from getting hotter.
For example, check out this teardown of Tesla battery pack, revealing the cooling system which is required for fast charging.
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
12
A lot of the chemical limitations to which speeds you can charge or discharge a battery actually get worse with decreasing temperature.
For example: the charge carrier mobility in a cold battery will be lower than in a warm one. That leads to a higher internal resistance. So you can't charge or discharge as fast, because the charges simply don't move as fast.
That's why on the cold days of winter, starter batteries have a harder time starting cars, because they simply can't deliver as much current. For charging, it's all the same.
psmears
  • 678
Marcus Müller
  • 88,280
  • 131
  • 237
    I interpreted the question more like "If I keep the battery at 30 °C using active cooling, can I keep increasing the current?", not what happens if you cool it down to sub-zero temperatures. – pipe Jan 17 '18 at 09:08
  • Hm, in that case, you should really write an answer (because, yes, that will within limits, help, but find its technical boundaries in electrode currents and still, limited mobility) to complement mine! (I'd upvote that.) – Marcus Müller Jan 17 '18 at 09:10
  • @pipe, but which part of the battery -- you can only cool the case (or the outside of individual cells in a custom pack) but that's not likely to be where the heat is generated, and there are plenty of factors more important than thermal conductivity in selecting materials for batteries – Chris H Jan 17 '18 at 14:27
    @pipe, thing is, you *can't* keep a battery at 30 °C using active cooling. A battery isn't a thermal superconductor, so you'll have a temperature gradient between the outside where your cooling system is, and the guts of the battery where the heat is produced. If you try to keep the inside at 30, the outer layers will be colder and won't charge as well; if you keep the outside at 30, the inside will be hotter. – Mark Jan 17 '18 at 23:47
  • @Mark Not sure why you're answering me since I'm not asking the question. If you know all this about batteries you should post an answer. – pipe Jan 18 '18 at 08:52
  • More internal resistance' Can't I push more power by increasing input voltage? – neverMind9 May 25 '18 at 19:54
  • Have you *read* Bruce's answer?! – Marcus Müller May 25 '18 at 19:58
If you charge too fast, then because the heat transfer is not instantaneous the plates buckle due to thermal expansion and create localised « shorts » which can then cause catastrophic failure.
And yes, been there seen it done : hi rate charger set to 24v on a 12v battery : By someone a few slices short of a loaf...
Solar Mike
  • 6,319
