On some synthesizers, there is a strip called ribbon controller, to wipe your finger over and it detects pressure. It's a bit similar to a mobile phone's LCD touch panel, except that it is one-diagonal (horizontal only) and the accuracy is (probably) less. It's typically around 10cm/4" and the amount of pressure is normally not checked (just pressed or not). Also simultaneous presses are not supported.
It is used for adding an effect to a sound, like vibration (pitch), volume, filter cutoff or other effects.
It looks like the black square in the buttom left (under the joystick).
I have an idea to make something like this myself, but I was wondering how it is called in 'electronic' terms. I tried to search for ribbon controller, but I get some Play Station 4 ribbon 'controller' which I don't think is the same. It is also possible to buy readily made separate ribbon controllers but these cost like 300 euro and normally come with a MIDI box (while I want to create my own functionality, MIDI related or not).
