Here is my personal advice. Please note that I'm not a real expert in this kind of things (especially on Atmel), so forgive me for any mistake. Most of the knowledge here comes from this and this posts.
You can access the flash memory (and so read the binary) from the outside (with a ISP programmer) or the inside (with some code).
As for the outside "attacks", the atmega has some fuse bits (read this answer for more info). Particularly the Lock Bit Protection ones can prevent anyone from reading and writing the flash and eeprom. Just program both LB1 and LB2 (IMPORTANT: the note on the datasheet says "Program the Fuse bits and Boot Lock bits before programming the LB1 and LB2."). From the moment you program them, nobody (not even you) will be allowed to read or write a new program on the microcontroller; the only way to write it back again is to perform a Chip Erase routine, which destroys the program on the uC.
As for inside "attacks", even with this protection an internal bootloader has access to the flash contents. You cannot prevent anything which programs from reading the memory, since at least once it needs to read back what was written (also the lock bits allow you to restrict write or write+read, but not only read). For this reason there is no way to prevent it in hardware. You can modify the bootloader to reject read requests, then program BLB10 to prevent reflashing a bootloader. But, in the end, do these product really need a bootloader? Do you really think that you will need to ask your customers to reprogram them? And if the answer is yes, how will you protect the binary files you will send them to be programmed? Anyway, I think that there is a high probability that in your application you can remove the bootloader and be more safe.
IN ANY CASE:
According to my experience, nobody will ever try to "steal" your work, because 50% of times it is easier to rewrite it from scratch because it is simple (and disassembling your code will be much more difficult than rewriting it), and 50% of times it is easier to rewrite it from scratch because it is complicated (and disassembling it will be a PITA and take ages, so better to start again from scratch). Have you ever tried to read code written by someone else? Well, now increase that difficulty by 1000x because it is generated automatically, and...
Ok, don't you believe me? I wrote a program for arduino, compiled, then disassembled the binary (following the procedure here). Can you understand what it does?
Disassembly of section .sec1:
00000000 <.sec1>:
0: 0c 94 5c 00 jmp 0xb8 ; 0xb8
4: 0c 94 6e 00 jmp 0xdc ; 0xdc
8: 0c 94 6e 00 jmp 0xdc ; 0xdc
c: 0c 94 6e 00 jmp 0xdc ; 0xdc
10: 0c 94 6e 00 jmp 0xdc ; 0xdc
14: 0c 94 6e 00 jmp 0xdc ; 0xdc
18: 0c 94 6e 00 jmp 0xdc ; 0xdc
1c: 0c 94 6e 00 jmp 0xdc ; 0xdc
20: 0c 94 6e 00 jmp 0xdc ; 0xdc
24: 0c 94 6e 00 jmp 0xdc ; 0xdc
28: 0c 94 6e 00 jmp 0xdc ; 0xdc
2c: 0c 94 6e 00 jmp 0xdc ; 0xdc
30: 0c 94 6e 00 jmp 0xdc ; 0xdc
34: 0c 94 6e 00 jmp 0xdc ; 0xdc
38: 0c 94 6e 00 jmp 0xdc ; 0xdc
3c: 0c 94 6e 00 jmp 0xdc ; 0xdc
40: 0c 94 15 01 jmp 0x22a ; 0x22a
44: 0c 94 6e 00 jmp 0xdc ; 0xdc
48: 0c 94 6e 00 jmp 0xdc ; 0xdc
4c: 0c 94 6e 00 jmp 0xdc ; 0xdc
50: 0c 94 6e 00 jmp 0xdc ; 0xdc
54: 0c 94 6e 00 jmp 0xdc ; 0xdc
58: 0c 94 6e 00 jmp 0xdc ; 0xdc
5c: 0c 94 6e 00 jmp 0xdc ; 0xdc
60: 0c 94 6e 00 jmp 0xdc ; 0xdc
64: 0c 94 6e 00 jmp 0xdc ; 0xdc
68: 00 00 nop
6a: 00 00 nop
6c: 24 00 .word 0x0024 ; ????
6e: 27 00 .word 0x0027 ; ????
70: 2a 00 .word 0x002a ; ????
72: 00 00 nop
74: 00 00 nop
76: 25 00 .word 0x0025 ; ????
78: 28 00 .word 0x0028 ; ????
7a: 2b 00 .word 0x002b ; ????
7c: 04 04 cpc r0, r4
7e: 04 04 cpc r0, r4
80: 04 04 cpc r0, r4
82: 04 04 cpc r0, r4
84: 02 02 muls r16, r18
86: 02 02 muls r16, r18
88: 02 02 muls r16, r18
8a: 03 03 mulsu r16, r19
8c: 03 03 mulsu r16, r19
8e: 03 03 mulsu r16, r19
90: 01 02 muls r16, r17
92: 04 08 sbc r0, r4
94: 10 20 and r1, r0
96: 40 80 ld r4, Z
98: 01 02 muls r16, r17
9a: 04 08 sbc r0, r4
9c: 10 20 and r1, r0
9e: 01 02 muls r16, r17
a0: 04 08 sbc r0, r4
a2: 10 20 and r1, r0
a4: 00 00 nop
a6: 00 08 sbc r0, r0
a8: 00 02 muls r16, r16
aa: 01 00 .word 0x0001 ; ????
ac: 00 03 mulsu r16, r16
ae: 04 07 cpc r16, r20
b8: 11 24 eor r1, r1
ba: 1f be out 0x3f, r1 ; 63
bc: cf ef ldi r28, 0xFF ; 255
be: d8 e0 ldi r29, 0x08 ; 8
c0: de bf out 0x3e, r29 ; 62
c2: cd bf out 0x3d, r28 ; 61
c4: 21 e0 ldi r18, 0x01 ; 1
c6: a0 e0 ldi r26, 0x00 ; 0
c8: b1 e0 ldi r27, 0x01 ; 1
ca: 01 c0 rjmp .+2 ; 0xce
cc: 1d 92 st X+, r1
ce: a9 30 cpi r26, 0x09 ; 9
d0: b2 07 cpc r27, r18
d2: e1 f7 brne .-8 ; 0xcc
d4: 0e 94 5f 01 call 0x2be ; 0x2be
d8: 0c 94 ce 01 jmp 0x39c ; 0x39c
dc: 0c 94 00 00 jmp 0 ; 0x0
e0: e1 eb ldi r30, 0xB1 ; 177
e2: f0 e0 ldi r31, 0x00 ; 0
e4: 24 91 lpm r18, Z
e6: ed e9 ldi r30, 0x9D ; 157
e8: f0 e0 ldi r31, 0x00 ; 0
ea: 94 91 lpm r25, Z
ec: e9 e8 ldi r30, 0x89 ; 137
ee: f0 e0 ldi r31, 0x00 ; 0
f0: e4 91 lpm r30, Z
f2: ee 23 and r30, r30
f4: 09 f4 brne .+2 ; 0xf8
f6: 3b c0 rjmp .+118 ; 0x16e
f8: 22 23 and r18, r18
fa: 39 f1 breq .+78 ; 0x14a
fc: 23 30 cpi r18, 0x03 ; 3
fe: 91 f0 breq .+36 ; 0x124
100: 38 f4 brcc .+14 ; 0x110
102: 21 30 cpi r18, 0x01 ; 1
104: a9 f0 breq .+42 ; 0x130
106: 22 30 cpi r18, 0x02 ; 2
108: 01 f5 brne .+64 ; 0x14a
10a: 24 b5 in r18, 0x24 ; 36
10c: 2f 7d andi r18, 0xDF ; 223
10e: 12 c0 rjmp .+36 ; 0x134
110: 27 30 cpi r18, 0x07 ; 7
112: 91 f0 breq .+36 ; 0x138
114: 28 30 cpi r18, 0x08 ; 8
116: a1 f0 breq .+40 ; 0x140
118: 24 30 cpi r18, 0x04 ; 4
11a: b9 f4 brne .+46 ; 0x14a
11c: 20 91 80 00 lds r18, 0x0080 ; 0x800080
120: 2f 7d andi r18, 0xDF ; 223
122: 03 c0 rjmp .+6 ; 0x12a
124: 20 91 80 00 lds r18, 0x0080 ; 0x800080
128: 2f 77 andi r18, 0x7F ; 127
12a: 20 93 80 00 sts 0x0080, r18 ; 0x800080
12e: 0d c0 rjmp .+26 ; 0x14a
130: 24 b5 in r18, 0x24 ; 36
132: 2f 77 andi r18, 0x7F ; 127
134: 24 bd out 0x24, r18 ; 36
136: 09 c0 rjmp .+18 ; 0x14a
138: 20 91 b0 00 lds r18, 0x00B0 ; 0x8000b0
13c: 2f 77 andi r18, 0x7F ; 127
13e: 03 c0 rjmp .+6 ; 0x146
140: 20 91 b0 00 lds r18, 0x00B0 ; 0x8000b0
144: 2f 7d andi r18, 0xDF ; 223
146: 20 93 b0 00 sts 0x00B0, r18 ; 0x8000b0
14a: f0 e0 ldi r31, 0x00 ; 0
14c: ee 0f add r30, r30
14e: ff 1f adc r31, r31
150: ee 58 subi r30, 0x8E ; 142
152: ff 4f sbci r31, 0xFF ; 255
154: a5 91 lpm r26, Z+
156: b4 91 lpm r27, Z
158: 2f b7 in r18, 0x3f ; 63
15a: f8 94 cli
15c: ec 91 ld r30, X
15e: 81 11 cpse r24, r1
160: 03 c0 rjmp .+6 ; 0x168
162: 90 95 com r25
164: 9e 23 and r25, r30
166: 01 c0 rjmp .+2 ; 0x16a
168: 9e 2b or r25, r30
16a: 9c 93 st X, r25
16c: 2f bf out 0x3f, r18 ; 63
16e: 08 95 ret
170: 3f b7 in r19, 0x3f ; 63
172: f8 94 cli
174: 80 91 05 01 lds r24, 0x0105 ; 0x800105
178: 90 91 06 01 lds r25, 0x0106 ; 0x800106
17c: a0 91 07 01 lds r26, 0x0107 ; 0x800107
180: b0 91 08 01 lds r27, 0x0108 ; 0x800108
184: 26 b5 in r18, 0x26 ; 38
186: a8 9b sbis 0x15, 0 ; 21
188: 05 c0 rjmp .+10 ; 0x194
18a: 2f 3f cpi r18, 0xFF ; 255
18c: 19 f0 breq .+6 ; 0x194
18e: 01 96 adiw r24, 0x01 ; 1
190: a1 1d adc r26, r1
192: b1 1d adc r27, r1
194: 3f bf out 0x3f, r19 ; 63
196: ba 2f mov r27, r26
198: a9 2f mov r26, r25
19a: 98 2f mov r25, r24
19c: 88 27 eor r24, r24
19e: 82 0f add r24, r18
1a0: 91 1d adc r25, r1
1a2: a1 1d adc r26, r1
1a4: b1 1d adc r27, r1
1a6: bc 01 movw r22, r24
1a8: cd 01 movw r24, r26
1aa: 42 e0 ldi r20, 0x02 ; 2
1ac: 66 0f add r22, r22
1ae: 77 1f adc r23, r23
1b0: 88 1f adc r24, r24
1b2: 99 1f adc r25, r25
1b4: 4a 95 dec r20
1b6: d1 f7 brne .-12 ; 0x1ac
1b8: 08 95 ret
1ba: 8f 92 push r8
1bc: 9f 92 push r9
1be: af 92 push r10
1c0: bf 92 push r11
1c2: cf 92 push r12
1c4: df 92 push r13
1c6: ef 92 push r14
1c8: ff 92 push r15
1ca: 0e 94 b8 00 call 0x170 ; 0x170
1ce: 4b 01 movw r8, r22
1d0: 5c 01 movw r10, r24
1d2: 88 ee ldi r24, 0xE8 ; 232
1d4: c8 2e mov r12, r24
1d6: 83 e0 ldi r24, 0x03 ; 3
1d8: d8 2e mov r13, r24
1da: e1 2c mov r14, r1
1dc: f1 2c mov r15, r1
1de: 0e 94 b8 00 call 0x170 ; 0x170
1e2: dc 01 movw r26, r24
1e4: cb 01 movw r24, r22
1e6: 88 19 sub r24, r8
1e8: 99 09 sbc r25, r9
1ea: aa 09 sbc r26, r10
1ec: bb 09 sbc r27, r11
1ee: 88 3e cpi r24, 0xE8 ; 232
1f0: 93 40 sbci r25, 0x03 ; 3
1f2: a1 05 cpc r26, r1
1f4: b1 05 cpc r27, r1
1f6: 58 f0 brcs .+22 ; 0x20e
1f8: 21 e0 ldi r18, 0x01 ; 1
1fa: c2 1a sub r12, r18
1fc: d1 08 sbc r13, r1
1fe: e1 08 sbc r14, r1
200: f1 08 sbc r15, r1
202: 88 ee ldi r24, 0xE8 ; 232
204: 88 0e add r8, r24
206: 83 e0 ldi r24, 0x03 ; 3
208: 98 1e adc r9, r24
20a: a1 1c adc r10, r1
20c: b1 1c adc r11, r1
20e: c1 14 cp r12, r1
210: d1 04 cpc r13, r1
212: e1 04 cpc r14, r1
214: f1 04 cpc r15, r1
216: 19 f7 brne .-58 ; 0x1de
218: ff 90 pop r15
21a: ef 90 pop r14
21c: df 90 pop r13
21e: cf 90 pop r12
220: bf 90 pop r11
222: af 90 pop r10
224: 9f 90 pop r9
226: 8f 90 pop r8
228: 08 95 ret
22a: 1f 92 push r1
22c: 0f 92 push r0
22e: 0f b6 in r0, 0x3f ; 63
230: 0f 92 push r0
232: 11 24 eor r1, r1
234: 2f 93 push r18
236: 3f 93 push r19
238: 8f 93 push r24
23a: 9f 93 push r25
23c: af 93 push r26
23e: bf 93 push r27
240: 80 91 01 01 lds r24, 0x0101 ; 0x800101
244: 90 91 02 01 lds r25, 0x0102 ; 0x800102
248: a0 91 03 01 lds r26, 0x0103 ; 0x800103
24c: b0 91 04 01 lds r27, 0x0104 ; 0x800104
250: 30 91 00 01 lds r19, 0x0100 ; 0x800100
254: 23 e0 ldi r18, 0x03 ; 3
256: 23 0f add r18, r19
258: 2d 37 cpi r18, 0x7D ; 125
25a: 20 f4 brcc .+8 ; 0x264
25c: 01 96 adiw r24, 0x01 ; 1
25e: a1 1d adc r26, r1
260: b1 1d adc r27, r1
262: 05 c0 rjmp .+10 ; 0x26e
264: 26 e8 ldi r18, 0x86 ; 134
266: 23 0f add r18, r19
268: 02 96 adiw r24, 0x02 ; 2
26a: a1 1d adc r26, r1
26c: b1 1d adc r27, r1
26e: 20 93 00 01 sts 0x0100, r18 ; 0x800100
272: 80 93 01 01 sts 0x0101, r24 ; 0x800101
276: 90 93 02 01 sts 0x0102, r25 ; 0x800102
27a: a0 93 03 01 sts 0x0103, r26 ; 0x800103
27e: b0 93 04 01 sts 0x0104, r27 ; 0x800104
282: 80 91 05 01 lds r24, 0x0105 ; 0x800105
286: 90 91 06 01 lds r25, 0x0106 ; 0x800106
28a: a0 91 07 01 lds r26, 0x0107 ; 0x800107
28e: b0 91 08 01 lds r27, 0x0108 ; 0x800108
292: 01 96 adiw r24, 0x01 ; 1
294: a1 1d adc r26, r1
296: b1 1d adc r27, r1
298: 80 93 05 01 sts 0x0105, r24 ; 0x800105
29c: 90 93 06 01 sts 0x0106, r25 ; 0x800106
2a0: a0 93 07 01 sts 0x0107, r26 ; 0x800107
2a4: b0 93 08 01 sts 0x0108, r27 ; 0x800108
2a8: bf 91 pop r27
2aa: af 91 pop r26
2ac: 9f 91 pop r25
2ae: 8f 91 pop r24
2b0: 3f 91 pop r19
2b2: 2f 91 pop r18
2b4: 0f 90 pop r0
2b6: 0f be out 0x3f, r0 ; 63
2b8: 0f 90 pop r0
2ba: 1f 90 pop r1
2bc: 18 95 reti
2be: 78 94 sei
2c0: 84 b5 in r24, 0x24 ; 36
2c2: 82 60 ori r24, 0x02 ; 2
2c4: 84 bd out 0x24, r24 ; 36
2c6: 84 b5 in r24, 0x24 ; 36
2c8: 81 60 ori r24, 0x01 ; 1
2ca: 84 bd out 0x24, r24 ; 36
2cc: 85 b5 in r24, 0x25 ; 37
2ce: 82 60 ori r24, 0x02 ; 2
2d0: 85 bd out 0x25, r24 ; 37
2d2: 85 b5 in r24, 0x25 ; 37
2d4: 81 60 ori r24, 0x01 ; 1
2d6: 85 bd out 0x25, r24 ; 37
2d8: 80 91 6e 00 lds r24, 0x006E ; 0x80006e
2dc: 81 60 ori r24, 0x01 ; 1
2de: 80 93 6e 00 sts 0x006E, r24 ; 0x80006e
2e2: 10 92 81 00 sts 0x0081, r1 ; 0x800081
2e6: 80 91 81 00 lds r24, 0x0081 ; 0x800081
2ea: 82 60 ori r24, 0x02 ; 2
2ec: 80 93 81 00 sts 0x0081, r24 ; 0x800081
2f0: 80 91 81 00 lds r24, 0x0081 ; 0x800081
2f4: 81 60 ori r24, 0x01 ; 1
2f6: 80 93 81 00 sts 0x0081, r24 ; 0x800081
2fa: 80 91 80 00 lds r24, 0x0080 ; 0x800080
2fe: 81 60 ori r24, 0x01 ; 1
300: 80 93 80 00 sts 0x0080, r24 ; 0x800080
304: 80 91 b1 00 lds r24, 0x00B1 ; 0x8000b1
308: 84 60 ori r24, 0x04 ; 4
30a: 80 93 b1 00 sts 0x00B1, r24 ; 0x8000b1
30e: 80 91 b0 00 lds r24, 0x00B0 ; 0x8000b0
312: 81 60 ori r24, 0x01 ; 1
314: 80 93 b0 00 sts 0x00B0, r24 ; 0x8000b0
318: 80 91 7a 00 lds r24, 0x007A ; 0x80007a
31c: 84 60 ori r24, 0x04 ; 4
31e: 80 93 7a 00 sts 0x007A, r24 ; 0x80007a
322: 80 91 7a 00 lds r24, 0x007A ; 0x80007a
326: 82 60 ori r24, 0x02 ; 2
328: 80 93 7a 00 sts 0x007A, r24 ; 0x80007a
32c: 80 91 7a 00 lds r24, 0x007A ; 0x80007a
330: 81 60 ori r24, 0x01 ; 1
332: 80 93 7a 00 sts 0x007A, r24 ; 0x80007a
336: 80 91 7a 00 lds r24, 0x007A ; 0x80007a
33a: 80 68 ori r24, 0x80 ; 128
33c: 80 93 7a 00 sts 0x007A, r24 ; 0x80007a
340: 10 92 c1 00 sts 0x00C1, r1 ; 0x8000c1
344: ed e9 ldi r30, 0x9D ; 157
346: f0 e0 ldi r31, 0x00 ; 0
348: 24 91 lpm r18, Z
34a: e9 e8 ldi r30, 0x89 ; 137
34c: f0 e0 ldi r31, 0x00 ; 0
34e: 84 91 lpm r24, Z
350: 88 23 and r24, r24
352: 99 f0 breq .+38 ; 0x37a
354: 90 e0 ldi r25, 0x00 ; 0
356: 88 0f add r24, r24
358: 99 1f adc r25, r25
35a: fc 01 movw r30, r24
35c: e8 59 subi r30, 0x98 ; 152
35e: ff 4f sbci r31, 0xFF ; 255
360: a5 91 lpm r26, Z+
362: b4 91 lpm r27, Z
364: fc 01 movw r30, r24
366: ee 58 subi r30, 0x8E ; 142
368: ff 4f sbci r31, 0xFF ; 255
36a: 85 91 lpm r24, Z+
36c: 94 91 lpm r25, Z
36e: 8f b7 in r24, 0x3f ; 63
370: f8 94 cli
372: ec 91 ld r30, X
374: e2 2b or r30, r18
376: ec 93 st X, r30
378: 8f bf out 0x3f, r24 ; 63
37a: c0 e0 ldi r28, 0x00 ; 0
37c: d0 e0 ldi r29, 0x00 ; 0
37e: 81 e0 ldi r24, 0x01 ; 1
380: 0e 94 70 00 call 0xe0 ; 0xe0
384: 0e 94 dd 00 call 0x1ba ; 0x1ba
388: 80 e0 ldi r24, 0x00 ; 0
38a: 0e 94 70 00 call 0xe0 ; 0xe0
38e: 0e 94 dd 00 call 0x1ba ; 0x1ba
392: 20 97 sbiw r28, 0x00 ; 0
394: a1 f3 breq .-24 ; 0x37e
396: 0e 94 00 00 call 0 ; 0x0
39a: f1 cf rjmp .-30 ; 0x37e
39c: f8 94 cli
39e: ff cf rjmp .-2 ; 0x39e
Will it be easier to reverse-engineer the code above or to write from scratch a program that (spoiler alert)
turns on and off a LED with a period of 2 seconds
Just to be more clear, this file is generated
starting from the blink example, compile, then take the "Blink.ino.with_bootloader.hex" file (the one you'll get by reading the memory from the atmega) and disassembled with the command avr-objdump -j .sec1 -d -m avr5 "Blink.ino.with_bootloader.hex" > "Blink.ino.with_bootloader.txt"
