I've been thinking about the skin effect and that got me thinking: When high frequency current goes through a superconductor, does it still radiate off like it would with copper?
Asked
Active
Viewed 394 times
1What have you found so far in your search? – pipe Dec 24 '17 at 17:30
1Well, what causes radiation? – PlasmaHH Dec 24 '17 at 17:39
Yes. There are radiations due to the AC current in the conductor, and thermal radiations due to the resistance of the conductor, which are lower for supraconductors than copper. – TEMLIB Dec 24 '17 at 17:49
2Superconductors have zero resistance. That's what makes them superconductors. – Ian Bland Dec 24 '17 at 17:57
7If the current is not DC, then I think some radiation would come off of the conductor due to a time varying magnetic field. In other words, a superconducting antenna would still be an antenna. – user57037 Dec 24 '17 at 18:16
Yes. Regardless of the resistance in a conductor, when a time varying current flows, it gives rise to a time varying magnetic field outside the conductor. When conditions are right, that time-varying magnetic field will give rise to a transverse electromagnetic wave (TEM).
In other words, an antenna constructed from super-conducting elements would still function as an antenna. The fact that the series resistance is zero does not prevent the antenna from functioning.
user57037
- 28,915
- 1
- 28
- 81
1If the current is the same, I think the radiation would be the same. – user57037 Dec 25 '17 at 19:50
I said if the current is the same, the radiation would be the same. The resistance may mean that the copper radiator requires a slightly higher voltage to achieve the same current. – user57037 Dec 26 '17 at 02:50
what about this? https://www.quora.com/Does-skin-effect-occur-in-superconductors – Max Dec 27 '17 at 04:01
1Post a new question. If skin effect still occurs, that would imply a non-uniform current density throughout the conductor cross-section. Superconductivity applies only up to some maximum current density. Above that, the super-condcutor has non-zero resistance. If skin effect concentrates the current density into the outer surface of the conductor, it may reach that limit at a lower total current. – user57037 Dec 27 '17 at 04:14
1It should maybe be mentioned that the [radiation resistance](https://en.wikipedia.org/wiki/Radiation_resistance) effect means a superconducting antenna would present a nonzero resistance to the rest of the circuit, even while still superconducting, because some of the energy of the current in the antenna would be transferred to the generated EM waves. – zwol Jun 06 '19 at 15:42
It also means superconductors still have inductance (no point to superconducting coils if it didnt) – DKNguyen Sep 08 '19 at 21:57
