I have a device which has a dc barrel jack with inside + and outside -. If I plug in a barrel connector which has 2 wires to connect to a DC voltage source (battery) how do I know which wire to connect to the positive terminal and which wire to the negative terminal?
Asked
Active
Viewed 2,527 times
3use a continuity tester – jsotola Dec 21 '17 at 03:12
Some Chinese Stuff has DC barrel connector with Pos on the outside and Neg on the inside so be catreful . – Autistic Dec 21 '17 at 04:33
Almost all stuff has +ve centre, -ve outside **EXCEPT** guitar effects pedals (as I found out to my surprise a few months ago) – Neil_UK Dec 21 '17 at 06:09
Not all cables have printed polarity indicators, so your best bet is to use a multimeter in continuity testing mode as mentioned by @jsotola.
BBales
- 145
- 1
- 8
