200 meters is pretty far to go for I2C, since it was originally intended for short-distance intra-board communication. However, using a bus buffer as you describe and running at lower clock speeds will make long cable runs possible.
This application note from NXP shows 50m performance for the PCA9600 you're looking at:
The PCA9615 is a related part that uses a differential I2C protocol, and is rated to 3 meter lengths at full speed (1MHz). I've used this part without issue operating at 400kHz over a 10 meter CAT6 cable.
Ethernet may be worth looking into, as it was designed for long distances--perhaps a Raspberry Pi on each end, acting as master and slave respectively?
Related question here regarding max length of an I2C bus, with notes regarding bus capacitance.
