I need to send 16 bits of data through serial UART to LabVIEW. I have 16bits of data frames with 1 start bit, 1 stop bit, and 1 parity bit. Is it possible to change the number of data bits in VISA component of NI LabVIEW to 16bits.By default it is 8 bit. is this impossible change number of data bits to 16 in VISA serial?
Asked
Active
Viewed 408 times
You can copy the contents of the "VISA Configure Serial Port (Instr).vi" and change the serial settings:databits to whatever you want. I sincerely doubt it'll work though. The hardware itself has to support the frame size and I've never heard of a modem supporting larger frames than 10 bits.
pgvoorhees
- 2,496
- 16
- 14
I sent 16 bit data frames from FPGA a custom UART component in vhdl and takes data to the PC using a USB to TTL converter. so if I can change the data bits to 16 in VISA is it possible to acquire 16bit data? – oppo Dec 07 '17 at 16:13
I'd just try it and find out. It's a pretty trivial change. Just copy the innards of the VI i referenced above, change the bit length and use the reference it produces to try to read/write data to the converter. – pgvoorhees Dec 07 '17 at 17:34
@oppo, PC hardware is unlikely to support receiving that. Your FPGA should send two frames of 8 bits. – Simon Richter Nov 04 '21 at 13:17
